Hello all,
I tried to add the buienradar weather component to my home assistant instance. I managed to add it and choose the desired weather station (schiphol). However when I create a lovelace weather card it doesn’t show the current temperature or any other sensors. It does however show the forecast.
I have another home assistant running at my parents house, also with an buienradar weather card. On their system the weather card shows a lot more info including the current temperature and pressure. They are also using the schiphol weather station.
I checked the configuration side by side and there’s nothing I can find that differs.
I’m at a loss here and would love some help figuring it out!
Some additional info:
On the log I am getting the following errors:
2020-02-11 02:25:39 WARNING (MainThread) [buienradar.buienradar_json] Data element with key=‘rainlasthour’ not loaded from br data!
2020-02-11 02:25:39 WARNING (MainThread) [buienradar.buienradar_json] Data element with key=‘temperature’ not loaded from br data!
2020-02-11 02:25:39 WARNING (MainThread) [buienradar.buienradar_json] Data element with key=‘feeltemperature’ not loaded from br data!
2020-02-11 02:25:39 WARNING (MainThread) [buienradar.buienradar_json] Data element with key=‘visibility’ not loaded from br data!
Thanks!
