Since I upgraded to version 0.102.1 I constantly get this error:
Unable to parse data from Buienradar.(Msg: Location data is invalid.)
Same overhere since the update.
Now Iâm in doubt if the reason for this error is the update to 0.102.1. My nearest weather station is âVoorschotenâ. On https://www.buienradar.nl/nederland/weerbericht/weerstations the âVoorschotenâ location doesnât contain data.
Will change my location to a working location later this evening to test.
Interesting - my nearest location is also Voorschoten⌠could be coincidence but you never know
Itâs a coincidence. Just changed my location to âVolkelâ and the buienradar works without any error.
So the error isnât the upgrade to 0.102.1, itâs something with our weather station
Yep, same here. âVoorschotenâ is down.
Iâve tried to use another weather station like âRotterdamâ, âVolkelâ, etc. But I donât receive any data on those either. Do you guys also experience this? When I check the Buienradar XML I can clearly see that âVoorschotenâ is down. But all the others are up and running. I canât get them to show up in HA.
Try tracking it down in the States view. I changed from Voorschoten to Rotterdam weerstation and restarting Home Assistant all my BR sensors got renamed with numbers at the end. Youâll have to modify the groups / cards with the updated names of sensors to get all your display / automations to work again.
Voorschoten seems to be working again over here.
