HI All
I currently have a setup where I use 2 raspberry pi as pi-hole blockers. My older Pi B+ is the primary, whilst my Pi3+ is running home assistant with the Pi-Hole add-on… Now I had this setup running for a while without issue,
I would monitor both of the servers, using the pi-hole sensor…
However over the past few weeks, it appears that the sensor for the built in pi-hole doesn’t get detected during a reboot, and therefore the sensors don’t show up in home assistant…
The funny thing is if I go to the add-on, and open the web page, it looks like it is working as intended.
I have a feeling it might be that it hasn’t loaded in time before the sensors pick it up…
Is there a way to force the sensors to try and pick it up again…
Thanks a lot
