I just want to have single buttons for switching on and off several light groups and my covers. I understood that I need a template for that but to be honest that seems two levels about what I can or better what I understood. There are several examples in the doc but I have the feeling none of them are what I´m looking for.
Also what is the difference between a template and script?
I don’t understand what your “single buttons” should do exactly. Turn on/off multiple entities? Or turn on/off different things based on the state of another thing?
A script executes multiple actions in a sequence. A template is used for multiple things, to extract values and from an input/entity and modify them or to create advanced conditions/trigger/actions in automations.
It’s meant just to turn on the ground floor lights on or if with a single button. Same for my covers. I want to create a HomeKit Like Button with the custom button card to do so.
This is probably easily solved with a light gorup ant the light.toggle service.
For the covers try @kanga_who suggestion or maybe you can write a JS template in lovelace ttat determines the needed service based on the states of the entities.
Yeah, a template light is easy as well. This example uses a scene to active a group of lights, called “bedroom lights”, but you can easy make a group and just call the light.turn_on service in place of homeassistant.turn_on
“Easy” is relative for me it’s currently hard to dig into this stuff because of Kids, Job and despite i understand English to a certain level when it comes to this I need to surrender
I will try it in the evening and give you guys feedback.
