Building My Smart Home from Scratch with Claude Code + Home Assistant
As a long-time HA user, I recently moved into a new home and decided to set up everything from zero using Claude Code as my primary tool. The result: scenes, automations, batch device configuration, and a polished dashboard — all with minimal manual intervention.
The whole project is open-sourced at ha-config-as-code. Clone it, open with Claude Code, and start chatting about your needs. It includes project context (CLAUDE.md) and custom skills out of the box.
Core Idea: Config as Code via HA API
Instead of editing lengthy YAML files, I use Python scripts that talk to the HA REST/WebSocket API to manage everything. For example, setting all 60+ lights to “last state” on power-on is a single setup_power_on_state.py script with a for loop — not dozens of YAML entity edits.
This approach also means the AI agent doesn’t need to parse massive YAML files as context. Each task is a self-contained script.
What I Built
Lighting (60+ devices, Matter + Xiaomi)
  • Light groups by room and by function (task lighting vs. ambient strips) via create_groups.py
  • Adaptive Lighting across the house (setup_adaptive_lighting.py): cool for bathrooms, neutral for common areas, warm for bedrooms — replacing all native circadian lighting features
  • Batch power-on state set to “last state” (setup_power_on_state.py)
Scenes
Three main scenes, all generated through conversation with Claude Code:
  1. Guest Mode — brighter, cooler light in common areas
  2. Theater Mode — dim the accent strips, turn off other lights
  3. Sleep Mode — lights off in bedrooms
You can also ask Claude Code to analyze your recent logs and suggest new scenes/automations.
Switch Bindings
All smart switches set to wireless mode (setup_wireless_switches.py), with a unified binding scheme (e.g., left single-press toggles room lights). Claude Code also generated a printable HTML manual for family and guests.
Automations
This is where Claude Code truly shines. I describe what I want in natural language, and it generates reliable automations — sometimes even proactively suggesting automations based on my device inventory and usage patterns.
Key automations:
  • Presence-based lighting — occupancy sensors in kitchen/bathroom trigger lights via HA (not vendor apps)
  • Water leak alert — kitchen sensor triggers phone notification + a decorative lamp flashes red
  • Appliance done notifications — washer/dryer/dishwasher completion announced via HomePod TTS
  • Pet monitoring — cat litter box usage, water intake, low litter alerts, full waste bin alerts — all one-shot prompted, with shopping reminders added to a to-do list
  • Arrival mode — a virtual switch exposed to Apple Home, triggered by iPhone geofencing + door lock, so no need to run the HA app in background
  • Auto ventilation — bathroom fan starts on toilet occupancy, stops a few minutes after leaving
  • Auto dehumidification — fan runs when bathroom humidity exceeds threshold, stops when it drops below. The threshold was automatically calibrated from actual shower data.
Iterative Workflow
You don’t need to get everything right in one shot. I iteratively refine automations by chatting with Claude Code. For example, the dehumidification threshold was tuned by asking it to analyze humidity data from an actual shower session.
Dashboard: Material Design 3
Built a Material Design 3 themed dashboard using Mushroom cards and custom cards. Frequently used controls on the home tab (for a wall-mounted tablet), with sub-tabs for lighting, climate, pets, etc.
Fun Addition: Daily Pokémon
A random Pokémon fetched daily via PokéAPI, displayed on the dashboard. Its image is used as the Material You base color source for automatic theme color extraction.
E-ink Display
An ESPHome-connected e-ink display showing HA sensor data — including a Claude Code usage dashboard pushed from my dev machine via API.
Takeaway
There are many approaches to AI + smart home (voice assistants as LLM front-ends, Node-RED, n8n, etc.). What makes the Claude Code + HA API approach different is that it produces reusable, version-controlled scripts rather than one-off voice commands or visual flows. You describe what you want, and get a working automation — no documentation hunting, no dragging nodes.
Home Assistant’s powerful and open API makes it the ideal platform for this agentic workflow. If you’re comfortable with a CLI tool and want to try a fundamentally different way to manage your smart home, give it a shot:
GitHub: yzlnew/ha-config-as-code
Happy to answer any questions!
Nice! I did something similar but went the yaml route vs python. But to your point, you can focus on “What you want” and Claude figures out “how to do it”. I too spent time on humidity routines, and the changes were based on how a humidity sensor responded to an actual shower being taken. And like you, I could feed the sensor history graph to Claude, discuss alternatives and pick one… And it works really well.
The code always has to be reviewed. What I found more than anything is that Claude was trying to add functional features that were inferred in the ton of scrolling AI agents provide in answers but really not asked for. So I made a “training and limits” file for Claude to refer to… take action only on my requests, not Claude suggestions. Only suggest when I ask for alternative solutions in a comment. Even little things like “only provide brief responses to my requests” as it over-answers like most AI agents do. Annoying to go through all the scrolling and uses up valuable time / tokens / symbols.
If you’re going to touch a live install I can’t stop you… Please be incredibly careful you can smoke your install in seconds. Be paranoid about backup and…
Then tell Claude about this
Its not perfect and will never e complete but…
Excellent job
I chose Python over YAML for several reasons. YAML is more easy to maintain by humans but not for agents. When dealing with a ton of entities, it’s more efficient and token friendly to use a for-loop or if-else in Python.
Thanks for the kind reminder. I highly recommend to start a new instance and allow Claude or Codex to migrate from a previous one. In my case, I moved to a new house so I decided to start fresh here. In addition to backups, I tried to make all the scripts idempotent so I can roll back at any git commit.
Yep - One misplaced curly bracket ENDS your configuration.yaml. file… It’s not a fun time. And starting new is completely impractical for entrenched installations. I literally have > 25 THOUSAND ents in my install. :slight_smile:
Yeah, it’s a good point. That makes more sense to configure through API with scripts rather than YAML. I don’t use any YAML at this repo except for my e-ink dashboard.
Really enjoyed going through ha-config-as-code. Routing everything through scripts/ha_api.py with the HA_EXTERNAL_URL → HA_URL fallback is the kind of small decision most config-as-code HA projects miss, and it makes a real difference when you’re moving between local and remote setups. Making the 10-step sequence idempotent is also genuinely thoughtful — that’s the part that makes this workable with a Claude Code agent, since re-runs converge instead of duplicating entities. Impressive piece of work overall.
One thing I got curious about while reading, since .env.example suggests you’re expecting people to fork this:
Right now HA_SSH_PASSWORD and HA_TOKEN live in the same .env. Totally fine for your own machine — but for forkers, HA OS SSH credentials and long-lived API tokens end up sharing a blast radius. setup_scenes.py doesn’t need SSH at all, but it can still read HA_SSH_PASSWORD via os.environ if anything in the dependency tree ever got compromised. And when someone wants to pull Xiaomi / HomeKit pairing into config-as-code too (feels like a natural next step given where the repo is heading), .env quietly becomes the single most sensitive file in the repo. Have you thought about that, or has the single-user setup kept it from becoming an issue so far?
Reason I ask — a few of us have been building an open-source credential proxy called NyxID that targets exactly this shape: config-as-code in public git, credentials stay out of .env. Server-side storage, per-script short-lived scoped tokens, rotation in one place. The part that felt really aligned with your repo: it speaks MCP, so your .claude/skills/interface-design agent could request HA_TOKEN scoped to just setup_dashboard.py and have no access to HA_SSH_PASSWORD during that call.
Honestly, your ha-config-as-code would be a lovely reference implementation for this shape. No pressure either way — really great work on the project regardless, and happy to chat if anything comes up.
