Built in MQTT broker, arduino and DHT11 problem
Hello, i tryed very much solutions, but i dont know, what i do bad. :frowning: I use Wemos D1 with WIFI and DHT11 sensor with this code
// Get ESP8266 going with Arduino IDE
// - https://github.com/esp8266/Arduino#installing-with-boards-manager
// Required libraries (sketch -> include library -> manage libraries)
// - PubSubClient by Nick ‘O Leary
// - DHT sensor library by Adafruit
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
#include <DHT.h>
#define wifi_ssid "ssid"
#define wifi_password "secret"
#define mqtt_server "hassio.local"
#define mqtt_user ""
#define mqtt_password ""
#define humidity_topic "sensor/humidity"
#define temperature_topic "sensor/temperature"
#define DHTTYPE DHT11
#define DHTPIN  4
WiFiClient espClient;
PubSubClient client(espClient);
DHT dht(DHTPIN, DHTTYPE, 11); // 11 works fine for ESP8266
void setup() {
  Serial.begin(115200);
  dht.begin();
  setup_wifi();
  client.setServer(mqtt_server, 1883);
void setup_wifi() {
  delay(10);
  // We start by connecting to a WiFi network
  Serial.println();
  Serial.print("Connecting to ");
  Serial.println(wifi_ssid);
  WiFi.begin(wifi_ssid, wifi_password);
  while (WiFi.status() != WL_CONNECTED) {
    delay(500);
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  Serial.println("IP address: ");
  Serial.println(WiFi.localIP());
void reconnect() {
  // Loop until we're reconnected
  while (!client.connected()) {
    Serial.print("Attempting MQTT connection...");
    // Attempt to connect
    // If you do not want to use a username and password, change next line to
    // if (client.connect("ESP8266Client")) {
    if (client.connect("ESP8266Client", mqtt_user, mqtt_password)) {
      Serial.println("connected");
    } else {
  Serial.print("failed, rc=");
  Serial.print(client.state());
  Serial.println(" try again in 5 seconds");
  // Wait 5 seconds before retrying
  delay(5000);
bool checkBound(float newValue, float prevValue, float maxDiff) {
  return !isnan(newValue) &&
         (newValue < prevValue - maxDiff || newValue > prevValue + maxDiff);
long lastMsg = 0;
float temp = 0.0;
float hum = 0.0;
float diff = 1.0;
void loop() {
  if (!client.connected()) {
    reconnect();
  client.loop();
  long now = millis();
  if (now - lastMsg > 2000) {
    lastMsg = now;
    float newTemp = dht.readTemperature();
    float newHum = dht.readHumidity();
    if (checkBound(newTemp, temp, diff)) {
      temp = newTemp;
      Serial.print("New temperature:");
      Serial.println(String(temp).c_str());
      client.publish(temperature_topic, String(temp).c_str(), true);
    if (checkBound(newHum, hum, diff)) {
      hum = newHum;
      Serial.print("New humidity:");
      Serial.println(String(hum).c_str());
      client.publish(humidity_topic, String(hum).c_str(), true);
Serial monitor show humidity and temperature right
http://fii.cz/pctzyzfa
In configuration.yalm i have
mqtt:
  - platform: yr
  - platform: mqtt
    state_topic: "sensor/temperature"
    unit_of_measurement: "°C"
  - platform: mqtt
    state_topic: "sensor/humidity"
    unit_of_measurement: "%"
But Hassio show nothing. :frowning: http://fii.cz/nhrhapq
Please, what i do wrong?
Hi!
This is how i solved this.
  - platform: mqtt
    state_topic: 'tele/esp8266_ledTak/SENSOR'
    name: 'Temperature kitchen 1'
    unit_of_measurement: '°C'
    value_template: '{{ value_json.AM2301.Temperature }}'
  - platform: mqtt
    name: 'Humidity kitchen 1'
    unit_of_measurement: '%'
    value_template: '{{ value_json.AM2301.Humidity }}'
You have to change AM2301 to DHT11 and topics.
I tryed, but doesnt work. :frowning:
Can you connect to the broker with another client, like in the testing your setup page (see the last line) and paste the output.
I have no Linux and i use built in borker. How can i do from windows?
Download mqttfx and connect to your broker and subscribe to # and see what your ESP sends to your broker.
Nothing to do, just in log:
2018-11-25 18:03:13,047 INFO — BrokerConnectorController : onConnect
2018-11-25 18:03:13,048 INFO — ScriptsController : Clear console.
2018-11-25 18:03:13,051 INFO — MqttFX ClientModel : MqttClient with ID af77176de04b4bd08ac03f2abebf5037 assigned.
2018-11-25 18:03:13,172 INFO — MqttFX ClientModel : session present: false
2018-11-25 18:03:33,553 INFO — SubscribeController : onSubscribe
2018-11-25 18:03:33,659 ERROR — MqttFX ClientModel : Error subscribing to topic: de.jensd.mqttfx.entities.Topic@f94afbe
org.eclipse.paho.client.mqttv3.MqttException: MqttException
at org.eclipse.paho.client.mqttv3.MqttClient.subscribe(MqttClient.java:438) ~[org.eclipse.paho.client.mqttv3-1.2.0.jar:?]
at org.eclipse.paho.client.mqttv3.MqttClient.subscribe(MqttClient.java:424) ~[org.eclipse.paho.client.mqttv3-1.2.0.jar:?]
at de.jensd.mqttfx.model.MqttFXClientModel.subscribe(MqttFXClientModel.java:908) ~[MQTT.fx-jfx.jar:?]
at de.jensd.mqttfx.ui.subscribe.SubscribeController.onSubscribe(SubscribeController.java:228) ~[MQTT.fx-jfx.jar:?]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:1.8.0_181]
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) ~[?:1.8.0_181]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) ~[?:1.8.0_181]
at java.lang.reflect.Method.invoke(Unknown Source) ~[?:1.8.0_181]
at sun.reflect.misc.Trampoline.invoke(Unknown Source) ~[?:1.8.0_181]
at sun.reflect.GeneratedMethodAccessor5.invoke(Unknown Source) ~[?:?]
at sun.reflect.misc.MethodUtil.invoke(Unknown Source) ~[?:1.8.0_181]
at javafx.fxml.FXMLLoader$MethodHandler.invoke(FXMLLoader.java:1771) ~[jfxrt.jar:?]
at javafx.fxml.FXMLLoader$ControllerMethodEventHandler.handle(FXMLLoader.java:1657) ~[jfxrt.jar:?]
at com.sun.javafx.event.CompositeEventHandler.dispatchBubblingEvent(CompositeEventHandler.java:86) ~[jfxrt.jar:?]
at com.sun.javafx.event.EventHandlerManager.dispatchBubblingEvent(EventHandlerManager.java:238) ~[jfxrt.jar:?]
at com.sun.javafx.event.EventHandlerManager.dispatchBubblingEvent(EventHandlerManager.java:191) ~[jfxrt.jar:?]
at com.sun.javafx.event.CompositeEventDispatcher.dispatchBubblingEvent(CompositeEventDispatcher.java:59) ~[jfxrt.jar:?]
at com.sun.javafx.event.BasicEventDispatcher.dispatchEvent(BasicEventDispatcher.java:58) ~[jfxrt.jar:?]
at com.sun.javafx.event.EventDispatchChainImpl.dispatchEvent(EventDispatchChainImpl.java:114) ~[jfxrt.jar:?]
at com.sun.javafx.event.BasicEventDispatcher.dispatchEvent(BasicEventDispatcher.java:56) ~[jfxrt.jar:?]
at com.sun.javafx.event.EventUtil.fireEventImpl(EventUtil.java:74) ~[jfxrt.jar:?]
at com.sun.javafx.event.EventUtil.fireEvent(EventUtil.java:49) ~[jfxrt.jar:?]
at javafx.event.Event.fireEvent(Event.java:198) ~[jfxrt.jar:?]
at javafx.scene.Node.fireEvent(Node.java:8411) ~[jfxrt.jar:?]
at javafx.scene.control.Button.fire(Button.java:185) ~[jfxrt.jar:?]
at com.sun.javafx.scene.control.behavior.ButtonBehavior.mouseReleased(ButtonBehavior.java:182) ~[jfxrt.jar:?]
at com.sun.javafx.scene.control.skin.BehaviorSkinBase$1.handle(BehaviorSkinBase.java:96) ~[jfxrt.jar:?]
at com.sun.javafx.scene.control.skin.BehaviorSkinBase$1.handle(BehaviorSkinBase.java:89) ~[jfxrt.jar:?]
at com.sun.javafx.event.CompositeEventHandler$NormalEventHandlerRecord.handleBubblingEvent(CompositeEventHandler.java:218) ~[jfxrt.jar:?]
at com.sun.javafx.event.CompositeEventHandler.dispatchBubblingEvent(CompositeEventHandler.java:80) ~[jfxrt.jar:?]
at com.sun.javafx.event.EventUtil.fireEvent(EventUtil.java:54) ~[jfxrt.jar:?]
at javafx.scene.Scene$MouseHandler.process(Scene.java:3757) ~[jfxrt.jar:?]
at javafx.scene.Scene$MouseHandler.access$1500(Scene.java:3485) ~[jfxrt.jar:?]
at javafx.scene.Scene.impl_processMouseEvent(Scene.java:1762) ~[jfxrt.jar:?]
at javafx.scene.Scene$ScenePeerListener.mouseEvent(Scene.java:2494) ~[jfxrt.jar:?]
at com.sun.javafx.tk.quantum.GlassViewEventHandler$MouseEventNotification.run(GlassViewEventHandler.java:394) ~[jfxrt.jar:?]
at com.sun.javafx.tk.quantum.GlassViewEventHandler$MouseEventNotification.run(GlassViewEventHandler.java:295) ~[jfxrt.jar:?]
at java.security.AccessController.doPrivileged(Native Method) ~[?:1.8.0_181]
at com.sun.javafx.tk.quantum.GlassViewEventHandler.lambda$handleMouseEvent$353(GlassViewEventHandler.java:432) ~[jfxrt.jar:?]
at com.sun.javafx.tk.quantum.QuantumToolkit.runWithoutRenderLock(QuantumToolkit.java:389) ~[jfxrt.jar:?]
at com.sun.javafx.tk.quantum.GlassViewEventHandler.handleMouseEvent(GlassViewEventHandler.java:431) ~[jfxrt.jar:?]
at com.sun.glass.ui.View.handleMouseEvent(View.java:555) ~[jfxrt.jar:?]
at com.sun.glass.ui.View.notifyMouse(View.java:937) ~[jfxrt.jar:?]
at com.sun.glass.ui.win.WinApplication._runLoop(Native Method) ~[jfxrt.jar:?]
at com.sun.glass.ui.win.WinApplication.lambda$null$147(WinApplication.java:177) ~[jfxrt.jar:?]
at java.lang.Thread.run(Unknown Source) [?:1.8.0_181]
Does MQTT.FX connect to the broker?
Yes, IT does
I solved it. I installed Mosquito Mqtt addon, seting up and whoho, its work!! :slight_smile:
