Did something change with the way Home Assistant binds its built-in mqtt broker? It has worked well until very recently, when mqtt stopped being available on the ethernet IP of my home assistant box(192.168.1.3
), instead only binding to 127.0.0.1
Is there any way to configure home assistant to bind to my ethernet interface/IP, or better yet to all interfaces/0.0.0.0
? The broker:
configuration option mentioned in the documentation looked like it may be the answer, but it has been deprecated
I use the Home Assistant docker image with docker-compose in Linux with network mode host
and the built-in MQTT broker for mqtt messages. Interestingly, 8123 is still accessible on all interfaces, only 1883 stopped binding to the eth interface - only available at localhost
