hello,
i use philips hue bulbs, but on/off happens via motion sensor…
is it possible to say that frequent on/off can radically reduce bulbs life-span?
thanks
hello,
thanks
No
Heat is the main killer of leds. Most manufacturers will recommend only using the leds at 80% brightness for just this reason.
On/off cycles should have no ill effects whatsoever!
Enjoy your bulbs
@nghtdr - wou, i thought on/off is killer…
cool i will try to setup to 80% if possible, thanks
On/off can affect the other electronic components badly, but a smart bulb is hardly ever really off, it is just dimmed to 0 brightness.
