Bulb transition time for non-dimmable bulbs
I have a case where a Sunricher inwall dimmer controls a LED lamp that is not dimmable. When toggling the lamp the dimmer tries to dim the bulb from o to 100 and vice.versa in a transition time of about a couple of seconds. Because the lamp is not dimmable the result is a lag of 2 seconds before the lamp switch on or off.
I am trying to understand if this can be disabled in deConz or HA or it is a feature of the dimmer, but with no luck so far.
Do you guys have a similar case in your automation?
