Bulk Edit Statistics
My Gas import meter had a blip where it incorrectly recorded high values for two days,
Trying to edit this through the statistics editor is very tedious, as after adjusting a value, you have to start the whole cycle of select statistic, select date, select time etc.
It would be nice if you could stay on the box where you select the date/time after adjusting a statistic so you could just move on to the next one.
I would absolutely adorse this feature. Im deleting a LOT of PV 0.1kWh entries by hand at the moment.
Pressing adjust now for a single entry take you back to the main screen which is VERY cumbersome.
Its killing me slowly from the inside.
Why not a scrollable list of entries of sorty where you can set each and then click apply so its saved in bulk.
Voted, I also have to do a very tedious work in order to correct wrong energy datas on two days, it’s taking me ages to do since I have six different prices for electricity. The current UI is great to adjust one value, and horrible when you have to correct dozens at a time.
Yesss It would really be amazing if we could, at least, delete broken sensor data, thanks!
