Hi all. Not sure when or how this happened, but I have a bunch of entities that are read-only and report “This entity does not have a unique ID, therefore its settings cannot be managed from the UI.”
These include all of my Tile trackers, my Wireless Sensor Tags, Darksky, 1 script, and sun and memory and disk use sensors.
Any ideas what could be going on?
Wow. What timing. I just ran into this when I enabled allow_hue_groups for the Philips Hue integration. I previously configured the integration using discovery and that added the “light” devices for the color bulbs. When I enabled allow_hue_groups to also get the LightGroups per this page https://www.home-assistant.io/integrations/hue/ I ended up with all of these new entities but no new devices.
@The_Penguin that is just the way some integrations are. If they don’t have a UI configuration option (ie are configured by configuration.yaml) then that will be so.
