Busch-Jaeger 2-gang (6736-84) Zigbee switch - How to implement double-press, long-press, hold
a bit new to HA, read the documentation and several threads in the forum, but now abit stuck: Have installed the Busch-Jaeger 4-gang switch (Busch-Jaeger – 6736-84 Control Element for Switch/dimmer Zigbee 2gang Radio Control studio white - 63x63), together with the power adapter, so no switch or dimmer module, hence all 4 buttons usable.
I’m able to use each of the buttons in Automations and trigger actions by a single press (evaluating the “action subtype”, e.g.: “off_row_1”, “on_row_1”, etc.).
But I could not figure out how to implement double-press, long-press and hold actions (e.g. for calling scenes, dimming, etc.).
Would be great if someone, who has already implemented that for this device, could share the automation OR give me a hint to an automation for another device, which works in a similar way, which I could then build upon.
Thanks in advance! :grinning:
Here’s how the device shows up in Z2M:
This is the switch, by the way:
And these are the action subtypes as per Z2M:
Screenshot 2024-02-12 130215
Note: Briefly pressing and releasing a button triggers the off_row_X resp. on_row_X actions for the given row, long-pressing triggers the brightness_step_down_row_X/brightness_step_up_row_X state respectively (after about one second). When releasing the button after a long-press action, a brightness_stop_row_X will be issued with no distinction between the left or right button.
Would be great if someone would have an idea!
Thanks!
Hi Florian, just found your post by chance on Google. I’m trying to connect my BJ 6736 to HA using zigbee2mqt. While initial pairing works I get only endpoint 10 (which seems to be the upper row) and don’t see any events at all in z2m.
May I ask what setup you have used to make it work?
