For those of you who are using the Busch-Jaeger ZigBee LightLink switches within deCONZ I made a blueprint for a common light on/off/dimming scenario through Home Assistant. These switches come with up to four rockers and this blueprint allows you to configure every rocker individually.
Features:
- Simple off/on action (left/right press)
- Dimming up/down (long lef/right press)
- Custom
onscene
Supported switches:
- BJ 6737-xx, 6736-xx, 6735-xx
- BJ 6737/01-xx, 6736/01-xx, 6735/01-xx
blueprint:
name: BJ ZLL Switch Rocker Configuration
description: "Individually configure the rockers of your Busch-Jaeger ZigBee Light Link switches in deCONZ. Supports on/off, dimming and scene activation."
domain: automation
input:
switch_event_id:
name: Switch Event ID
description: The event id of the switch (a.k.a the switch name). You can find out the event id by using developer tools -> events and subscribing to `deconz_event`.
rocker:
description: Depending on the BJ ZLL switch model the switch might have up to four rockers. You can select which rocker you would like to program through this automation.
default: 1
selector:
number:
min: 1
max: 4
light:
description: The light you want to control through the automation.
selector:
entity:
integration: deconz
domain: light
transition:
description: The transition time for the brightness change.
default: 4
selector:
number:
min: 1
max: 10
ignore_on_button:
name: Ignore On Button
description: Enable if you only want to ignore events from the right rocker. You can then handle short button presses on that button through your own custom automation for maximum flexibility.
default: false
selector:
boolean:
ignore_off_button:
name: Ignore Off Button
description: Enable if you only want to ignore events from the left rocker. You can then handle short button presses on that button through your own custom automation for maximum flexibility.
default: false
selector:
boolean:
on_scene:
description: If you want to activate a scene with the right button of the rocker instead of simply calling `light.turn_on` you can reference the scene here.
default:
selector:
entity:
domain: scene
variables:
rocker: !input rocker
transition: !input transition
light: !input light
on_scene: !input on_scene
trigger_variables:
ignore_on_button: !input ignore_on_button
ignore_off_button: !input ignore_off_button
# Events for dimming (LONG_PRESS_HOLD and LONG_PRESS_RELEASE for both left and right rocker buttons
- platform: event
event_type: deconz_event
event_data:
id: !input switch_event_id
# Start long press left rocker
event: "{% if rocker == 1 %}1001{% elif rocker == 2 %}3001{% elif rocker == 3 %}5001{% else %}7001{% endif %}"
- platform: event
event_data:
# Stop long press left rocker
event: "{% if rocker == 1 %}1003{% elif rocker == 2 %}3003{% elif rocker == 3 %}5003{% else %}7003{% endif %}"
- platform: event
event_data:
# Start long press right rocker
event: "{% if rocker == 1 %}2001{% elif rocker == 2 %}4001{% elif rocker == 3 %}6001{% else %}8001{% endif %}"
- platform: event
event_data:
# Stop long press right rocker
event: "{% if rocker == 1 %}2003{% elif rocker == 2 %}4003{% elif rocker == 3 %}6003{% else %}8003{% endif %}"
# Short-press events for on/off.
# Note: In case `ignore_off_button`/`ignore_on_button` is set, we don't want to subscribe to these button events.
# That's why we are using the dummy event "9999" in that case.
- platform: event
event_data:
# Short press left rocker
event: "{% if not ignore_off_button and rocker == 1 %}1002{% elif not ignore_off_button and rocker == 2 %}3002{% elif not ignore_off_button and rocker == 3 %}5002{% elif not ignore_off_button and rocker == 4 %}7002{% else %}9999{% endif %}"
- platform: event
event_data:
# Short press right rocker
event: "{% if not ignore_on_button and rocker == 1 %}2002{% elif not ignore_on_button and rocker == 2 %}4002{% elif not ignore_on_button and rocker == 3 %}6002{% elif not ignore_on_button and rocker == 4 %}8002{% else %}9999{% endif %}"
- choose:
# Handle DIM DOWN events (long-press left rocker button).
# We are asking the light to move to minimum brightness within `transition` time. As soon as the button is released the transition is stopped.
- conditions:
- condition: template
value_template: '{{ trigger.event.data.event in (1001,3001,5001,7001) }}'
sequence:
- service: light.turn_on
entity_id: '{{light}}'
brightness: 3
transition: "{{transition}}"
# Handle DIM UP events (long-press right rocker button).
# We are asking the light to move to max brightness within `transition` time. As soon as the button is released the transition is stopped.
- conditions:
value_template: '{{ trigger.event.data.event in (2001,4001,6001,8001) }}'
sequence:
brightness: 255
# Handle DIM STOP events (release button after long-press event).
- conditions:
value_template: '{{ trigger.event.data.event in (1003,2003,3003,4003,5003,6003,7003,8003) }}'
sequence:
- service: deconz.configure
entity: '{{light}}'
# Set the `bri_inc` attribute through the REST API to stop any ongoing brightness transition.
# For groups and lights we need to write to a different endpoint. Note that the `is_deconz_group`
# is not good for detecting if it's a group because it does not work with rooms.
field: "{% if state_attr(light, 'all_on') != None %}/action{% else %}/state{% endif %}"
data: {"bri_inc": 0}
# Handle OFF event (short-press left rocker button).
- conditions:
value_template: '{{ trigger.event.data.event in (1002,3002,5002,7002) }}'
sequence:
- service: light.turn_off
# Handle ON event (short-press right rocker button) without activating scene.
- conditions:
value_template: '{{ not on_scene and trigger.event.data.event in (2002,4002,6002,8002) }}'
sequence:
# Handle ON event (short-press right rocker button) by activating scene.
- conditions:
value_template: '{{ on_scene and trigger.event.data.event in (2002,4002,6002,8002) }}'
sequence:
- service: scene.turn_on
entity_id: '{{on_scene}}'
