Hi all. Yesterday I recorded a sonoff s20 for the first time and I can’t make the relay activate or deactivate when the button is pressed. From home assistant it works fine. It is only from esphome that
I did not find what the code is. I thank you
A more serious question is it now necessary to use mqtt for devices recorded with esphome.
switch:
- platform: gpio
name: "Relay enchufe reposicion"
pin: GPIO12
binary_sensor:
- platform: gpio
pin:
number: GPIO0
mode:
input: true
pullup: true
inverted: true
name: "Boton enchufe resposicion"
- platform: status
name: "Estado enchufe resposicion"
- platform: gpio
pin: GPIO3
name: "Sensor enchufe resposicion"
