I’ve just moved to Home Assistant over the Christmas break from a different platform and its brilliant. I am however stuck with what sounds like a ridiculously simple thing.
I have some devices which are DMX controlled - I have installed the DMX integration and the the hardware is all working as it should.
One of the devices uses a channel for colour and positions on the ‘brightness’ channel slider correspond to different colours.
0-10 = red
11-20 = blue
21-30 = yellow
etc…
I’m trying to use the Button Card Configuration to create a series of buttons which recall each colour value but cant figure it out
I guess a more conventional example would be a lamp brightness slider where what you actually want is a set of buttons for off, 25%, 50%, 75% etc.
I’m embarrassed to ask such a simple question but despite having read lots of forum posts the solution just isn’t clear to me.
Thanks,
Joel.
