This is my lovelace yaml so far. What is the easiest most direct way to make the cover and the lock red when closed/locked and green when open/unlocked?
By default the icon color will change based on your selected theme. There isn’t a way to override it without using an addon. The card-mod will allow you to apply css styles to almost any card (can be installed manually or via HACS). It will work for the button. In your example for the garage and front door add the following style key (after installing card-mod and adding the js url to your resources):
cards:
- entity: cover.garadget
hold_action:
action: more-info
show_icon: true
show_name: true
show_state: false
tap_action:
action: toggle
type: button
style: |
:host {
--paper-item-icon-color: red
:host {
--paper-item-icon-active-color: green
- entity: lock.door
hold_action:
action: more-info
show_icon: true
show_name: true
show_state: false
tap_action:
action: toggle
type: button
style: |
:host {
:host {
