Button Card: help with border
I’m trying to create a custom button card that will show icons for two lamps and a title below. See right tile in the image below.
Basically, I want this tile to be similar to the two on the left with a border around the large square tile, but not around the individual lamp icons or the title (Family Room). Here’s my code so far:
- type: vertical-stack
  cards:
    - type: horizontal-stack
      cards:
        - type: custom:button-card
          entity: light.family_room_left_table_bulb
          icon: mdi:lamp
          show_name: false
          icon: mdi:lamp
          show_name: false
here you go
you can change the rounding of the corners in - border-radius: and the size of the name in - font-size:
with aspect_ratio: 1/1, you ensure that it is the same length on each side
icon: mdi:lamp
aspect_ratio: 1/1
show_name: true
tap_action:
  action: toggle
styles:
  card:
    - border-radius: 24px
  name:
    - font-size: 40px
and if you have colour-adjustable lamps, here’s something similar, but the card changes colour to match the lamp
icon: mdi:lamp
aspect_ratio: 1/1
show_name: false
tap_action:
  action: toggle
hold_action:
  action: more-info
styles:
  card:
    - background-color: |
          if (states['light.family_room_left_table_bulb'].state == 'on') {
            const rgb = states['light.family_room_left_table_bulb'].attributes.rgb_color;
            return `rgb(${rgb[0]}, ${rgb[1]}, ${rgb[2]})`;
          return 'var(--contrast10)';
  icon:
    - color: var(--black)
card_mod:
  style: |
    :host {
      height: 100% !important;
      width: 100% !important;
      max-width: 100% !important;
      margin: 0 !important;
      position: unset !important;
      display: grid !important;
Take a look at the stack-in-card. It is a bit old and sometimes needs the help of card_mod to remove borders and backgrounds but still useful.
[Stack-in-card] allows to group multiple cards into one card without the borders.
YAML code
type: custom:stack-in-card
card_mod:
  style: |
    ha-card {
      height: 250px;
cards:
    cards:
      entity: light.living_room1
      show_name: false
      styles:
        card:
          - border: none
      entity: light.living_room2
      show_name: false
      styles:
        card:
          - border: none
    entity: light.living_room_lights
    show_icon: false
    styles:
        card:
          - border: none
        name:
          - font-size: "30px"
You may need to play with the card’s dimensions to get it to match to rest.
EDIT: As a bonus, the “title” at the bottom is another custom:button-card that can be used to toggle the living room group, for example.
Just add border: none !important; or border-style: none !important; to the mod to remove the card border.
card_mod:
  style: |
    ha-card {
      height: 250px;
That would remove the border from the stack-in-card, which I assumed the OP wanted to keep in order to match the other cards which is why it wasn’t included in the top card.
Then I misunderstood
@kman42 This should be a good place to start.
cards:
      cards:
          icon: mdi:lamp
          show_name: false
          icon: mdi:lamp
          show_name: false
          cards:
              cards:
                  icon: mdi:lamp
                  card_mod:
                    style: |
                     ha-card {
                  icon: mdi:lamp
                  card_mod:
                    style: |
                     ha-card {
              card_mod:
                    style: |
                     ha-card {
That does not do what the OP is looking for.
This revised code uses Mushroom Light Cards for the individual lights in the stack-in-card; primary and secondary info is hidden, borders and backgrounds removed. The custom:button-card at the bottom is stylized to look like bottom of a Mushroom Light Card. Includes the original two cards on the left.
YAML Code
cards:
  - type: custom:mushroom-light-card
    layout: vertical
    icon: mdi:lightbulb
    layout: vertical
    icon: mdi:lamps
  - type: custom:stack-in-card
    card_mod:
      style: |
        ha-card {
          height: 100%;
    cards:
        cards:
            layout: vertical
            icon: mdi:lamp
            primary_info: none
            secondary_info: none
            card_mod:
              style: |
                ha-card {
                  border: none;
                  background: none;
            layout: vertical
            icon: mdi:lamp
            primary_info: none
            card_mod:
              style: |
                ha-card {
                  border: none;
                  background: none;
        show_icon: false
        show_state: true
        state_display: '[[[ return (entity.state = "on") ? `${parseInt(entity.attributes.brightness / 2.54)}%` : "Off" ]]]'
        styles:
          card:
            - border: none
            - margin-top: '-5px'
          name:
            - font-size: 14px
            - font-weight: bold
            - color: '#e1e1e1'
          state:
            - font-size: 12px
            - font-weight: bolder
            - line-height: 1.5
            - color: '#9b9b9b'
Thanks for the edit, but he didn’t mention using the Mushroom addon.
Isn’t this more of what he was requesting for the 3rd card with only the Button addon?
cards:
    entity: light.couch_light
    show_state: true
    aspect_ratio: 1/1
    styles:
      icon:
        - color: orange
      card:
        - background-color: '#1a1a1a'
        - font-size: 16px
    show_state: true
    aspect_ratio: 1/1
    styles:
      icon:
        - color: orange
      card:
        - font-size: 16px
    tap_action:
      action: toggle
    styles:
      card:
        - font-size: 10px
      grid:
        - grid-template-areas: |
            "light1 light2 "
            "light3 light3 "
        - grid-template-columns: 1fr 1fr
        - grid-template-rows: 5.3em 1fr 1fr
        - grid-gap: 0
    custom_fields:
      light1:
        card:
          entity: light.pc_lights
          aspect_ratio: 2/1
          show_name: false
          icon: mdi:lamp
          tap_action:
            action: toggle
          styles:
            grid:
                  "i"
              - grid-template-rows: 1fr
            card:
              - margin-top: 10px
              - padding: 0px
              - font-size: 10px
            icon:
              - height: 100%
              - color: orange
      light2:
        card:
          entity: light.bathroom_lights
          show_name: false
          icon: mdi:lamp
          aspect_ratio: 2/1
          tap_action:
            action: toggle
          styles:
            grid:
                  "i"
            card:
              - margin-top: 10px
              - padding: 0px
              - font-size: 10px
            icon:
              - height: 100%
              - color: orange
      light3:
        card:
          entity: light.bed_lights
          aspect_ratio: 3.7
          icon: none
          styles:
            grid:
                  "n"
            card:
              - margin-top: 30px
              - font-size: 16px
Thank you! This is exactly what I am looking to do. And thanks to everyone else that responded—sorry if my question wasn’t clear.
I’m not sure if I’m being trolled or what but I can play this game.
Look at the two cards on the left that the OP is already using; those are Mushroom Light cards
OP may not have know about the stack-in-card, hence my suggestion in Post #4.
Your design does not match the OP’s original image nor the request. You used custom:button-cards instead of the Mushroom Light cards which the OP stated “I want this tile to be similar to the two on the left”. You missed the border around the stack which was part of the request and was re-mentioned in Post 6. OP did not mention a third light; he wanted a title which in my design in Post 4 allowed toggling another light (or light group) with the use of the bottom custom:button-card (which could be easily removed if desired.).
Coming back to this one:
Done.
YAML code
cards:
    layout: vertical
    icon: mdi:lightbulb
    layout: vertical
    icon: mdi:lamps
    show_icon: false
    show_state: true
    state_display: |
    styles:
      card:
        - padding-top: 0
      grid:
        - grid-template-areas: '"button1 button2" "n n" "s s"'
        - grid-template-rows: min-content min-content
      name:
        - font-size: 14px
        - font-weight: bold
        - color: '#e1e1e1'
        - margin-top: '4px'
        - margin-bottom: '0px'
      state:
        - font-size: 12px
        - color: '#9b9b9b'
        - margin-top: '2px'
        - margin-bottom: '8px'
      button1:
        - padding: 0
      button2:
        - padding: 0
    custom_fields:
      button1:
        card:
          layout: vertical
          icon: mdi:lamp
          primary_info: none
          card_mod:
            style: |
              ha-card {
                border: none;
                background: none;
      button2:
        card:
          layout: vertical
          icon: mdi:lamp
          primary_info: none
          card_mod:
            style: |
              ha-card {
                border: none;
                background: none;
