Hello everybody:
How can I configure a custom: button-card to execute a script according to the state of a media player?
If it is in standby mode call script on
If it is on call script off
- type: custom:button-card
entity: media_player.playstation_4
action: call-service
??? service: automation.encender_ps4 or apagar_ps4
Scripts
encender_ps4:
alias: 'Encender PS4'
sequence:
- data:
entity_id: media_player.playstation_4
service: media_player.turn_on
apagar_ps4:
alias: 'Apagar PS4'
sequence:
- data:
service: media_player.turn_off
Hi! Can you give us more information regarding media_player.playstation_4 entity?
You can go to Developer Tools → States (Tab) → Find/Type “media_player.playstation_4” → There you will find state & state attribute.
You can copy and paste the available data there. It is important to know how we can get the data to know the status of “media_player.playstation_4”.
I don’t think you can. You can however make a script that does call on or the other depending on the state. Simply add a chooser to the script
The state of the media player is standby or idle.
What I need to know is if I can at the moment of clicking on the card call a script or the other script
Sin embargo, puede hacer un script que llame a uno u otro dependiendo del estado
That is what I need. According to the idle or standby state that calls the script that turns on the playstation or the script that turns it off
What do you want to happen if the states is playing or off?
I want that if I click on the card button and media_player.playstation_4 is in standby mode, it calls the script that turns on the play.
If it is on idle and I press the button card, turn it off
Hello! Can you try if this works for you? You need to use this YAML to create a script. Then, for your button card, you select this script as the target.
alias: Playstation Script
sequence:
- service: >-
{% if states('media_player.playstation_4') == 'standby' %}
{% elif states('media_player.playstation_4') == 'idle' %}
{% endif %}
mode: single
Below is the better approach by septillion-
sequence:
- choose:
- conditions:
- condition: state
state: standby
sequence:
- service: media_player.turn_on
- conditions:
- condition: state
state: idle
sequence:
- service: media_player.turn_off
default: []
mode: single
Excellent friend.
It worked perfect. That is what I needed.
Thank you very much for the help
Does it work if the state of the Playstation is in “playing” or “off”?
Maybe an error shows up in the logs?
That’s basically what I told you
And yeah, that script will throw an error is the state isn’t standby
or idle
because it will try to call an empty service. So I would just throw everything in a chooser with an empty default
sequence:
- choose:
- conditions:
- condition: state
state: standby
sequence:
- conditions:
- condition: state
state: idle
sequence:
default: []
mode: single
OK, thanks a lot. I’m going to prove it.
I just tried it in standby mode. Don’t test it off.
In the event that the play is off, I don’t think I can turn it on. I have the installation supervised and I can’t get it to work GitHub - dhleong/ps4-waker: Wake your PS4 over LAN (with help from the Playstation App)
Goodluck
Hope you can get it working.
