Button-card state updating
I’m having a little trouble with button-card that I was hoping someone could help me with.
This is my first attempt to use it.
I have a few buttons that are currently made using mushroom template cards. When tapped, a script triggers a scene and then updates an input_select with the now active scene. The current template card will update the color of the icon and the secondary info to reflect that it’s the active scene. I want to use button-card to do this. Everything is working, except the card is not updating the color or name field as I have it configured.
  large:
    layout: icon_label
    show_name: true
    show_label: true
    styles:
      label:
        - justify-self: left
        - padding-left: 10px
        - font-weight: bold
        - font-size: 15px
        - font: Ubuntu,sans-serif
      name:
        - align-self: center
        - font-size: 12px
        - color: rgba(155, 155, 155, 1)
        - font-weight: bold
      grid:
        - grid-template-areas: '"i l" "i n" "i s"'
        - grid-template-columns: 1fr 80%
      img_cell:
        - background: grey
        - border-radius: 6%
- type: horizontal-stack
            cards:
              - type: custom:button-card
                template: large
                icon: mdi:lightbulb-auto
                entity: input_select.basement_current_scene
                triggers_update: input_select.basement_current_scene
                label: Auto
                  [[[ if (states["input_select.basement_current_scene"].state =
                  "Auto") return "Active"; else return "Off"; ]]]
                tap_action:
                  action: call-service
                  service: script.basement_default_scene
                  data: {}
                  target: {}
                styles:
                  icon:
                    - color: >-
                        [[[ if
                        "Auto") return "rgba(243, 156, 18,1.0)"; else return
                        "grey"; ]]]
This is what it looks like currently. (Auto) is using button-card. The other 4 are using mushroom templates:
When a mushroom template button is pressed it should update like this:
and Auto should look like the other two.
Nevermind, I figured it out. Havent touched javascript in a while and needed to make a == not a single =.
