Button Event Identification Helper for Matter
Helps identify events sent by buttons from the Matter integration.
Assign buttons when you use the blueprint and when you press / tap / hold a button it will generate a notification in Home Assistant that indicates the type of event that was triggered (i.e. initial_press, short_release, etc.), along with a list of all event types supported by the button.
Useful for developing other blueprints and automations.
Requires the Matter integration.
blueprint:
  name: Matter - Button Event Identification Helper V1.0
  description: |
    Requires the [Matter integration](https://www.home-assistant.io/integrations/matter).
  author: Edward Wright
  domain: automation
  input:
    button:
      name: 'Matter Button Event(s)'
      description: Matter button(s) that you want to monitor.
      selector:
        entity:
          multiple: true
          filter:
            - integration: matter
              domain: event
              device_class: button
mode: single
max_exceeded: silent
triggers:
- trigger: state
  entity_id:
    !input button
actions:
  - action: notify.persistent_notification
    metadata: {}
      title: "{{ trigger.to_state['attributes']['friendly_name'] }} > {{ trigger.to_state['attributes']['event_type'] }}"
      message: "Supported Events: {{ trigger.to_state['attributes']['event_types'] }}"
