Button On/Off Control with Optional Actions
This automation blueprint maps an On Button and an Off Button (designed for event-based smart switches and remotes) to control any switch, light, or input boolean. It also includes support for optional secondary actions for each button press.
Features
  • Dual Button Mapping: Separate controls for turning a device On and Off.
  • Optional Actions: Run extra actions, scenes, or scripts alongside the standard On or Off states without needing separate automations.
  • Modern Event Triggers: Uses event-based triggers (such as initial_press) optimized for modern button devices.
  • Queued Mode: Gracefully handles rapid or simultaneous button presses.
Input Configuration Reference
Input Type Description
On Button Event Entity The button entity triggered when turning the device on (e.g., event.balcony_switch_button_1).
Off Button Event Entity The button entity triggered when turning the device off (e.g., event.balcony_switch_button_3).
Target Entity Target The switch, light, or input boolean to turn on and off.
Optional On Action Action (Optional) Additional action, script, or automation to execute when the On button is pressed.
Optional Off Action Action (Optional) Additional action, script, or automation to execute when the Off button is pressed.
Installation
Method 1: Click to Import (Easiest)
Click the badge below to import this blueprint directly into your Home Assistant instance:
Method 2: Manual Installation
  1. Download or clone the raw button_on_off.yaml file from this repository. button_on_off.yaml
  2. In your Home Assistant configuration directory, navigate to your blueprints folder (e.g., config/blueprints/automation/ufans123/).
  3. Paste the code into a file named button_on_off.yaml.
  4. Reload your automations or restart Home Assistant.
Method 3: Manual Installation using the Blueprints Dashboard (Easier)
  1. Copy the following URL…
https://github.com/ufans123/home-assistant-blueprints/blob/main/button_on_off.yaml
  1. Navigate to your Home Assistant Blueprints Dashboard UI
  2. In the bottom right corner click on the ‘Import blueprint’ button
  3. Paste in the URL and follow the prompts
FYI - Minor UI update added to clean up blueprint sections for ease of use.
