Hi, I have a Zigbee water leak sensor that takes time to set itself back to “no leak detected” state. I use it to monitor an AC drainage canister and have a big red conditional banner on top of my dashboard when it’s full. Leak detection is fine, No Leak takes time, and it’s annoying.
What I want is to tap this banner to set the sensor to “no leak” (obviously after I empty the can) and the banner to disappear.
I haven’t found a way to do this. Any tips? Thanks!
Don’t try to set a sensor state. Instead, set up a trigger-based template binary sensor as below: adjust for your sensor and button entities and states, then use that to trigger the banner. I’ve used device_class: moisture as the closest in the list.
template:
- trigger:
- platform: state
entity_id: input_button.leak_reset
- platform: state
entity_id: binary_sensor.leak_detector
binary_sensor:
- name: Filtered leak detector
state: "{{ 'off' if 'button' in trigger.entity_id else trigger.to_state.state }}"
