Button to exit "Map" Dashboard to come back to main dashboard
Hi there,
I have HA on a wall display using Fully Kiosk Browser, and have a button to open the map.
In the past I had it on a card on a specific dashboard with a button allowing me to call the “main” home dashboard where I called from.
I am now calling from that button the newly functionality “Map” dashboard … but how can I then have a button on it allowing me to come back to the main dashboard ?
Any solution ?
Many Thanks !!
Just set the new view in the map dashboard as a Subview, then you will have the back button!
Thanks a lot !!
As I a with Fully Kiosk, I have disabled the top and left menus for non admin, so I need to find out the option to keep the top menu allowing the “back” button :
kiosk_mode:
  admin_settings:
    hide_header: false
    hide_sidebar: false
  non_admin_settings:
    kiosk: true
the new map is just a dashboard like the others, you could change the layout end add another card to go back?
