Button Triggers Voice Assist Listen
Hello community.
I currently have Assist working with cloud, Gemini and starts with wake word, connected to the Voice Preview box and other mics and media players around the house.
I am trying to create an automation where clicking a button on my physical Onvis switch will prompt assistant to start listening - kind of making the button act as the wake word.
I am unable to find any entity or action where assist starts listening to link it to the button. Can you please assist on how to achieve that?
Hi Lou,
Could you solve it?
Thanks!
Add a button in the esphome code that will launch the voice assistant. I won’t go into details, since you should understand well what exactly you are doing
Thanks a lot, MCHK.
In case somebody needs the code:
switch:
    name: "Voice Assistant Trigger"
    turn_on_action:
      - if:
          condition:
            lambda: return !id(init_in_progress) && !id(color_changed);
          then:
            - if:
                condition:
                  switch.is_on: timer_ringing
                then:
                  - switch.turn_off: timer_ringing
                else:
                  - if:
                      condition:
                        media_player.is_announcing:
                      then:
                        media_player.stop:
                          announcement: true
                      else:
                        - if:
                            condition:
                              voice_assistant.is_running:
                            then:
                              - voice_assistant.stop:
                            else:
                              - if:
                                  condition:
                                    media_player.is_playing:
                                  then:
                                    - media_player.pause:
                                  else:
                                    - if:
                                        condition:
                                          and:
                                            - switch.is_off: master_mute_switch
                                            - not: voice_assistant.is_running
                                        then:
#                                          - script.execute:
#                                              id: play_sound
#                                              priority: true
#                                              sound_file: !lambda return id(center_button_press_sound);
#                                          - delay: 300ms
                                          - voice_assistant.start:
      - delay: 2s  # Optional: Automatisches Ausschalten
      - switch.turn_off: voice_assistant_trigger
Example automation to trigger (including lowering the volume of the media player). Just remove it, if you don’t need it:
alias: "Voice: Sprachassistent per Switch triggern"
triggers:
**YOUR TRIGGER**
actions:
  - service: input_number.set_value
      entity_id: **input_number.spotify_voice_save_volume_setting**
      value: "{{ state_attr('**media_player.spotifyplus**', 'volume_level') | float(0.5) }}"
  - service: media_player.volume_set
      entity_id: **media_player.spotifyplus**
      volume_level: 0.2
  - service: switch.turn_on
      entity_id: **switch.home_assistant_voice_abc_voice_assistant_trigger**
  - wait_for_trigger:
      - platform: state
        entity_id: **assist_satellite.home_assistant_voice_abc_assist_satellit**
        to: "idle"
    timeout: "00:00:10"
      volume_level: "{{ states('**input_number.spotify_voice_save_volume_setting**') | float(0.5) }}"
