Button up and down <input_select> Choose <input_select>.<options>
Have a smart washingmachine and struggle with some code.
I want to select the washing programm
I would like to select an item from one <input_select> that consists of one line. By means of a button up and down would be the possibility to scroll through the list. The input_select was created as a helper. The helper is filled with about 10 items
I use the integration for this:
select-list-card .
So two buttons and a input_select list.
The code in the custom button card I’m using doesn’t do what it’s supposed to. The tab_action late in the input_select list does not provide the scroll effect.
A button card made in love-lace horizontal stacked does work.
Can someone help me get started?
This works:
type: horizontal-stack
cards:
  - show_name: false
    show_icon: true
    type: button
    tap_action:
      action: perform-action
      perform_action: input_select.select_next
        entity_id: input_select.was_wasprogramma
        cycle: true
    entity: input_button.button_down
  - show_name: false
    show_icon: true
    type: button
    tap_action:
      perform_action: input_select.select_previous
        label_id: washingmachine_input_select
    entity: input_button.button_up
  - type: custom:select-list-card
    entity: input_select.was_wasprogramma
    icon: ""
    truncate: true
    show_toggle: false
    scroll_to_selected: true
    max_options: 1
This does not work…
      item2:
        card:
          type: custom:button-card
          template: custom_washer_grid_select_program
          custom_fields:
            item1:
              card:
                show_name: false
                show_label: false
                template:
                  - icon_info
                entity: >-
                  [[[ return variables.ulm_custom_washer_grid_select_programm
                state: null
                icon: mdi:upload-circle-outline
                tap_action:
                  action: call-service
                  service: input_select.select_previous
                  target: '[[[ variables.ulm_custom_washer_grid_select_programm ]]]'
                    cycles: true
                styles:
                  icon:
                    - transform: scale(1.9)
            item2:
              card:
                show_name: false
                show_label: false
                template:
                  - icon_info
                entity: >-
                state: null
                icon: mdi:download-circle-outline
                tap_action:
                  service: input_select.select_option
                  service_data:
                    entity_id: >-
                      [[[ return
                styles:
                  icon:
            item3:
              card:
                entity: >-
                icon: ''
                truncate: true
                show_toggle: false
                max_options: 1
