Button via ZigBee2Mqtt triggers switch but don’t know why
I have a IKEA Styrbar remote freshly added to zigbee2mqtt. When looking at the device info, i see that there are no automations, no scripts, and no scenes configured.
BUT when i press the on button on the remote, an other zigbee switch is triggered and my coffee maker turns on. If i press the off button, the coffee maker turns off.
I’ve never configured these actions (coffee maker ON/IFF) to be triggered for these buttons. The device info is empty. I don’t know why this is happening and can’t figure out how to reconfigure it.
Even if i remove and re-add the devices, the situation remains the same.
Any help is highly appreciated!
Thank you
Look at the logs of the zigbee switch. You should be able to see what triggers it, and from there you can dig more.
I’ve tried that. I see entries for the button and subsequent entries for the triggered switch, all matching the situation: press button → trigger switch
But I haven’t configured that to happen, and as such i don’t find a way to change the button actions (as nothing seems to be configured).
Maybe I’m missing a place where one can configure such actions for triggers, beyond scripts and automations?
If you remove the button from Z2M and try triggering the switch (without having the button joined to Z2M), does it still work?
If i delete the button from zigbee2mqtt, then nothing is triggered. If i add it again, then it triggers it again.
You could try this: Install GitHub - frenck/spook: Spook 👻 Not your homie and then rename the zigbee switch that is connected to your coffee maker. If the switch is configured in any way Spook should give you a notification that it is missing from for example an automation. If that doesn’t give you anything I would try renaming both devices and see if that solves anything.
Thank you for your time and suggestions!
I’ll give it a try.
Also you can check the “Bind” option in Z2M to see if it is directly bound to anything (probably not though)
