Since upgrading to 2023.4.1 I have buttons missing all over my dashboards, but the entity itself is still on HA and reports the proper value. I’ve tried on 5 different browsers and cleared cache so I don’t think it’s a caching issue.
For example, on my Weatherflow device you can see the buttons missing:
One of those is the relative humidity, which is present and has a value:
It’s not tied to just one integration, I have this across the board whether it’s template entities or non template entities. While I do use some mods in places, the screenshot above is 100% pure HA.
The same on 2023.4.3, also changed Android widget buttons and need’s to be recofigured. And some spaces loosed for several objects. Quit strange update.
Same error.
It is interesting that buttons are not visible on the desktop computer (Chrome browser) and in the Android app, while they are normally visible on the Chrome browser on the Android phone.
Had the same problem with custom button card, only appeared this morning with 2023.4.3, not related to buttons showing percentages (as was mentioned in a related issue).
Workaround is here:
EDIT: this fix is already merged into the code in version 2023.4.4 so you should get the fix by simply upgrading.
I can confirm that the work-around with going into your profile and changing one of the settings away from auto is a functional work-around for 2024.4.2. I’m not adding as a solution only because it is a work-around rather than a fix.
I’ve got the same issue, it has persisted sisnce i updated to 2023.4.1.
I upgraded to 2023.4.4 this morning and I still have the same problem. All my buttons are gone and when trying to create a new one, this is what it looks like:
