I did a search through my automations and found I only use the instant arm script. I couldn’t test it while my house sitter is home and I’m not. So thought there might be the chance it had changed due to @odechr’s question.
I noticed in the alarm.css file there are options for light themes, dark themes, etc. I’m not sure how to change the theme other than use the editor for custom colors.
I use the Google Light theme right now and would like to be able to get this alarm panel as close to that as possible.
Try clicking on that ugly button at the bottom - in will allow you to create a new theme.
If you’re expecting that the alarm can use HA theme that won’t work though.
I made automations in node red, so I can use your alarm with a chinese made esp8266 alarm box (so I can use xiaomi door sensors and hue motion sensors). Is there a way to get which sensor got triggered and send it in a notification?
thanks
