Bwalarm (akasma74 edition)
Before posting, I looked at resources/bwalarm/bwalarm.yaml, but I didn’t see where to reset the password. Is there specific line to edit in resources/bwalarm/bwalarm.yaml?
It’s here
Thanks, got it fixed!
How can I use Bwalarm as a card in lovelace? Is it possible? iframe for example.
I assume you don’t mean just using the alarm card?
If so, you may be able to use this: https://gist.github.com/balloob/580deaf8c3fc76948559c5963ed4d436
If you use an iframe you will get a double side menu. See this for an example: When I click on custom link added via panel_iframe: it opens the link but then creates a second sidebar
I wanted to have BWalarm directly on lovelace, though if add https://XXX.duckdns.org:8123/alarm to an iframe in panel mode It doubles the side bar.
download the panel-redirect.js from here put it into your /config/www folder then inside configuration.yaml you’ll want to put in the following code (I think this is right, play around with it a little bit if needed)
panel_custom:
  - name: panel-redirect
    # url_path needs to be unique for each panel_custom config
    url_path: redirect-bwalarm
    sidebar_title: BW Alarm  # you can type whatever name you want here
    sidebar_icon: mdi:gesture-tap-button # you can choose any icon you want
    module_url: /local/panel-redirect.js
    config:
      # Where you want to redirect to
      target: /alarm
Exactly what I said here:
I tried that module but it just creats another panel on the side bar. Imeant the iFrame card, not the panel. I have BWAlarm on the panel already. I wanted to have bwalarm on a card.
I haven’t tried it but how about this?
It works but with a double side bar
Is there anyway to force the Arming trigger to immediately arm, and bypass the arm delay set?
I have some remote controls I use to enable/disable the alarm when outside the house, and would like to be to create an automation that when the alarm is enabled with the remotes, it bypasses the arm delay.
However, I’d like to keep the delay enabled for when enabling the alarm from the control panel inside the house.
I know the documentation is not perfect but it has it.
Awesome! Little bit of a hidden feature, but found it, thank you!
Also, do you know if I can send a “triggered” command without the alarm being armed? I’d like to create a “panic” button on a remote.
Currently, I can’t trigger the alarm unless it was set in Away/Home mode first.
I also don’t want to just trigger the sirens, as I’d like it to not bypass the alarm, so all the other automations still work.
what exactly should happen when you press that button?
that’s correct because it only triggers from armed_xxx/warning state.
could you elaborate? the only thing the alarm does is changing its state.
the rest is down to your automatons.
You could do this with a simple automation, not requiring the bwalarm at all. Since you want it to work when the alarm is not armed then that seems like the logical solution.
Is there an issue open for this?
HTML custom panels have been deprecated
Just checking as I couldn’t find one.
I think there isn’t.
This is the PR:
I’ll create an issue later today.
I was wondering if someone could help me with this one.
My goal is when i arm the alarm that a media player, could be google home for instance, lets you know if a sensor is open.
I already tried creating a simple automation where the trigger is the state of the alarm and the condition is then whether one sensor is open or not.
Maybe the easiest way here would be to create a group with all the sensors in it and then measure the condition on the group instead of having a looooong condition list with all sensors?
The other part is to get the TTS to let me know the name of the sensor or sensors, so I don’t have to either open the app to see which sensor it is.
One of the problems I came across was that it doesn’t look like my alarm state is changing status when trying to arm, while a sensor is open.
I use the Bwalarm (akasma74 edition).
Anyone having some good suggestions or maybe a working example already?
Thanks… :+1:
