BWAlarm Issues
So today I noticed I can disarm my alarm without any pass code from the Lovelace dashboard?
When I click on disarm without entering any code it disarms?
When I arm / disarm from the BWAlarm panel it works as it should requiring pass code?
I then tried
So I checked my automatons and tried calling the services, this also disarmed the alarm without pass code?
I also tried changing my pass code but no success?
This cannot be a glitch as I have reinstalled BWAlarm from both HACS then manually, cleared cache etc.
Also to note, whatever method of installation I still get the following from the info tab.
Your Versions:
This integration: v1.12.4
Home Assistant: v0.114.2
Python: v(3,8,3,final,0)
This is as stated above after manual re installation from
UPDATE
Found the following after more googling
I still have the issue with the version revision?
