I have been playing with Caddy add-on for Hassio by Koryl Prince and also looking at security reports etc.
The below actually works BUT with the Content-Security-Policy I can’t actually access the front end anymore. If I go to https://securityheaders.com/ and scan my domain with the below configuration it comes up A+. If I remove the Content-Security-Policy it’s only an A and I get a warning:
Content Security Policy is an effective measure to protect your site from XSS attacks. By whitelisting sources of approved content, you can prevent the browser from loading malicious assets.
Any ideas how I can edit the following to make this work without locking myself out of the frontend?
I don’t have experience with this add on, but when you browser blocks content based on the CSP headers it will leave a detailed entry in the console, usually it’s just a case of adding a specific rule for the blocked resource.
i think i found the issue. i didn’t have the specific proxy set up for the IP of my caddy instance. once i explicitly added this, it seems i’m getting the source IPs forwarded to HA.
still need to read into more about setting IP bans at the Caddy level. i’ve noticed the past couple of weeks russia and france knocking on my door…
As well as x_forwarded_for you also need a trusted proxy to be set. I have 127.0.0.1 and then the real IP’s should be parsed through.
I also use the custom component authenticated so I have a badge showing last authenticated and a persistent notification for any new authenticated IP address.
I do also use ip_bans in my configuration.yaml.
I don’t know who or what might be hitting my IP address… But I’m pretty well obfuscated as I only have port 443 open now since I worked out how to use DNS validation for lets encrypt. I also only expose my IPv6 address so there is no IPv4 address that anyone can scan.
I’d be interested in seeing how you know about scans or connection attempts from Russia - is that just in your router logs? Also if you get fail2ban working with Caddy…
Here’s my config and you can see my Caddy config in the first post of the thread.
I also have 2FA enabled.
http:
# ssl_certificate: /ssl/fullchain.pem
# ssl_key: /ssl/privkey.pem
use_x_forwarded_for: true
trusted_proxies:
- 127.0.0.1
- ::1
ip_ban_enabled: true
login_attempts_threshold: 5
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
base_url: !secret base_http_url
So I found out how to enable the log file with this addon.
I added to my caddyfile:
log /data/requests.log {
rotate_size 50 # Rotate after 50 MB
rotate_age 90 # Keep rotated files for 90 days
rotate_keep 20 # Keep at most 20 log files
rotate_compress # Compress rotated log files in gzip format
The data directory is located at:
/usr/share/hassio/addons/data/fe41fc28_caddy
I can only access it from the host. You could get there from a console in Portainer as well but I can’t find it in the homeassistant root folder (as it’s in the Caddy container)
The /data folder is one of 3 bind mounts in the container and it is the only one with rw access unfortunately.
