Sure, that’s really short and simple :
[{"id":"53a567e0.517d58","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"c7c94832.64f0c8","type":"change","z":"53a567e0.517d58","name":"TimeStamp","rules":[{"t":"set","p":"payload","pt":"msg","to":"","tot":"date"}],"action":"","property":"","from":"","to":"","reg":false,"x":478,"y":85,"wires":[["cd35b838.9e87e8"]]},{"id":"9de6ba13.77d938","type":"api-call-service","z":"53a567e0.517d58","name":"Update Puissance","server":"ec30a50e.1b4f88","version":3,"debugenabled":false,"service_domain":"var","service":"set","entityId":"var.puissance","data":"{\"value\" : msg.payload}","dataType":"jsonata","mergecontext":"","mustacheAltTags":false,"x":1110,"y":85,"wires":[[]]},{"id":"3d9c8ed0.290722","type":"server-state-changed","z":"53a567e0.517d58","name":"Teleinfo Index","server":"ec30a50e.1b4f88","version":3,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"sensor.teleinfo_index","entityidfiltertype":"exact","outputinitially":true,"state_type":"str","haltifstate":"","halt_if_type":"num","halt_if_compare":"is","outputs":1,"output_only_on_state_change":false,"for":"","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"}],"x":87,"y":51,"wires":[["ec9c8099.e12c6"]]},{"id":"ec9c8099.e12c6","type":"delay","z":"53a567e0.517d58","name":"","pauseType":"rate","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"30","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":true,"x":284,"y":51,"wires":[["c7c94832.64f0c8","70a41cba.733214"]]},{"id":"cd35b838.9e87e8","type":"delay","z":"53a567e0.517d58","name":"","pauseType":"delay","timeout":"5","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":665,"y":85,"wires":[["c1fbf1d8.441ec"]]},{"id":"c1fbf1d8.441ec","type":"function","z":"53a567e0.517d58","name":"Calcul de Puissance","func":"var Timestamp = Number(msg.payload);\nvar Index = flow.get(\"Index\",\"file\");\nvar Prev_Index = flow.get(\"Prev_Index\",\"file\");\nvar Prev_Timestamp = flow.get(\"Prev_Timestamp\",\"file\");\nvar Prev_Puissance = flow.get(\"Prev_Puissance\",\"file\");\nvar Puissance;\n\n // Get a pretty date in the format: `Mar 20, 13:04`\nvar date = new Date().toLocaleDateString('fr-FR', {\n month: 'short',\n day: 'numeric',\n hour12: false,\n hour: 'numeric',\n minute: 'numeric'\n})\nvar statusText;\n\nif (isNaN(Prev_Index))\n{\n flow.set(\"Prev_Index\", Index, \"file\");\n flow.set(\"Prev_Timestamp\", Timestamp, \"file\"); \n}\nelse if ((Timestamp-Prev_Timestamp > 29000) && (Index > Prev_Index))\n{\n Puissance = Math.floor((Index-Prev_Index)/(Timestamp-Prev_Timestamp)*1000*3600);\n \n if (Puissance < 1000)\n {\n Puissance = Math.round(Puissance/10)*10;\n }\n else\n {\n Puissance = Math.round(Puissance/50)*50;\n }\n \n flow.set(\"Prev_Index\", Index, \"file\");\n flow.set(\"Prev_Timestamp\", Timestamp, \"file\");\n \n if (Puissance!=Prev_Puissance && Puissance < 10000)\n {\n\n statusText = Puissance + ` at: ${date}`\n node.status({fill: \"green\", shape: \"dot\", text: statusText});\n\n flow.set(\"Prev_Puissance\", Puissance, \"file\");\n msg.topic = \"Puissance\";\n msg.payload = Puissance;\n return msg;\n }\n}","outputs":1,"noerr":0,"initialize":"","finalize":"","x":882,"y":85,"wires":[["9de6ba13.77d938"]]},{"id":"70a41cba.733214","type":"change","z":"53a567e0.517d58","name":"Index Teleinfo","rules":[{"t":"set","p":"#:(file)::Index","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":488,"y":34,"wires":[[]]},{"id":"ec30a50e.1b4f88","type":"server","name":"Home Assistant","version":1,"legacy":false,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true}]
