I was wondering if it is possible to create a graph with Grafana that shows a cost overview of your electricity and gas consumption, that you read via your smart meter (Dutch meter, DSMR). So the number of kwh that you use per day is then converted into monetary values based on what you pay per kwh or m3 with your energy company.
I thought that this had already been mentioned on the forum, but I can not find it again unfortunately
But maybe someone reacts that has this already working in Grafana? I am very curious what you have to do to get it done.
It’s possible as long as you have a flat rate - i.e. there’s no price for peak/low hours. I still haven’t found a way and I don’t think it’s actually possible to do calculations if you have different rates.
In order to get this result, I’d suggest you take a look at emoncms
We have a fixed amount for both the low rate and high rate. The only question is how to set it up in Grafana But if there is a better platform to visualize data from Home Assistant in which you can also calculate prices of your gas and electricity consumption, then I would love to hear it
I got that same answer from the grafana community, as you can read here.
In another topic I also found interesting information and pictures how to set it up.
