arva
(Arva)
October 17, 2022, 7:56am
1
Hi!
I have heat pump connected over modbus and MQTT. Heat pump energy is measured by Shelly EM3.
Heat pump is heating both - hot water and under floor heating. I have this information from the pump:
There are three values:
“Heat” - floor heating
“Hot Water” - hot water heating
“Off” - heat pump is on idle. It still consumes about 95w of energy.
Now I have Shelly EM3 for measuring heat pump and here is the data:
What i try to achieve, is to have three separate energy sensors:
Floor Heating Energy
Hot Water Energy
Idle Energy
Any good ideas hot to move on?
henryk
(Henryk Plötz)
October 17, 2022, 8:02am
2
I think you can do this with the stock utility meter (Utility Meter - Home Assistant ) integration, by having three “tariffs
” (heating
, hot_water
, and idle
) and an automation that calls the select.select_option
service to switch between them as appropriate.
arva
(Arva)
October 17, 2022, 8:27am
3
Could you describe more in detail how to do this?
arva
(Arva)
October 26, 2022, 7:59am
4
So what i did was:
Added utility meter witht three tariff options: heat, hot_water and idle
And automation:
alias: Heat Pump Utility Meter Tariff Options
description: ""
- platform: state
entity_id:
- sensor.heat_pumo_prio
condition: []
- choose:
- conditions:
- condition: state
entity_id: sensor.heat_pumo_prio
state: Heat
sequence:
- service: select.select_option
option: heat
entity_id: select.heat_pump_daily_energy_tariffs
- conditions:
- condition: state
state: Hot Water
sequence:
option: hot_water
- conditions:
- condition: state
state: "Off"
sequence:
option: idle
mode: single
Everything works as excpected
