I’ve just started to get familiar with HA and pull values of power consumption and production. I’d like to have a nice graph like the energy dashboard to show both.
At the electricity meter (Apator Norax 3D) I use an IR-reader with Tasmota to get the consumption values. Unfortunately there is the total for consumption only, not for return to grid. But I can read the current consumption with can be positiv (for consumption) or negative for feed).
Furthermore I run a mini PV system. Those values I pull via command line.
So, I have total consumption and total production. What’s missing for the dashboard is the value of return to grid.
Is there any way to calculate that?
Currently my configuration.yaml looks as follows:
default_config:
frontend:
themes: !include_dir_merge_named themes
script: !include scripts.yaml
scene: !include scenes.yaml
command_line:
- sensor:
command: curl -s -u user:pass http://192.168.xx.xx/status.html | grep -E "\webdata_now_p(\s|$)" | cut -d'"' -f 2
unit_of_measurement: 'W'
scan_interval: 60
- sensor:
command: curl -s -u user:pass http://192.168.xx.xx/status.html | grep -E "\webdata_total_e(\s|$)" | cut -d'"' -f 2
unit_of_measurement: 'kWh'
scan_interval: 120
template:
- sensor:
- name: "Stromzähler Gesamt Verbrauch"
unique_id: "StromVerbrauch"
device_class: "energy"
state_class: "total_increasing"
state: >-
{{ float(states('sensor.tasmota_sml_total_in')) | round(3) }}
- sensor:
- name: "Stromzähler Aktuell"
unique_id: "StromAktuell"
state_class: "total"
state: >-
{{ states('sensor.tasmota_sml_power_cur') }}
- sensor:
state: >-
- sensor:
- name: "Stromzähler Aktuell Verbrauch"
unique_id: "StromAktuellVerbrauch"
state: >-
{% set curr_power = states('sensor.tasmota_sml_power_curr') | float %}
{% if curr_power > 0 %}
{{ curr_power }}
{% else %}
{{ 0 }}
{% endif %}
- sensor:
- name: "Stromzähler Aktuell Einspeisung"
unique_id: "StromAktuellEinspeisung"
state: >-
{% if curr_power < 0 %}
{{ -curr_power }}
{% else %}
{{ 0 }}
{% endif %}
- sensor:
- name: "Terasse Erzeugung Total"
state: "{{ states('sensor.power_balkon_pv_total') if states('sensor.power_balkon_pv_total') | float > 0 }}"
unique_id: "balkon_pv_energy"
- sensor:
- name: "Terasse Erzeugung Aktuell"
state: "{{ states('sensor.power_balkon_pv_now') }}"
state_class: "measurement"
unique_id: "balkon_pv_energy_now"
Thank you for any hints!
