Hi!
I’m not sure if this is a bug or that I have misunderstood something.
I have some Hue bulbs which I would like to change color_temp
on. At first glance I thought that I could use min_mireds
and max_mireds
and use the value between them to do some percentage calculation and use it as color_temp
argument for light.turn_on
. E.g:
- id: 'kristallkronan'
alias: Kristallkronan
- event_data:
button_name: flic_mac
click_type: hold
event_type: flic_click
platform: event
service: light.turn_on
entity_id: light.kristallkronan
data_template:
color_temp: >
{% set entity = 'light.kristallkronan' %}
{% set min = state_attr(entity, 'min_mireds') %}
{% set max = state_attr(entity, 'max_mireds') %}
{% set range = max - min %}
{% if is_state(entity, "off") %}
{{ min + (range * 0.50) | int }}
{% elif state_attr(entity, 'color_temp') == min %}
{{ min + (range * 0.25) | int }}
{% elif state_attr(entity, 'color_temp') <= min + (range * 0.25) | int %}
{% elif state_attr(entity, 'color_temp') <= min + (range * 0.50) | int %}
{{ min + (range * 0.75) | int }}
{% elif state_attr(entity, 'color_temp') <= min + (range * 0.75) | int %}
{{ max }}
{% elif state_attr(entity, 'color_temp') == max %}
{{ min }}
{% endif %}
But it seems like the maximum color_temp
I’m allowed to set is 454
even if the bulb itself tells me that it can handle a max of 500
min_mireds: 153
max_mireds: 500
brightness: 64
color_temp: 378
friendly_name: Kristallkronan
supported_features: 43
This discrepancy makes my attempt to do this calculation dynamically impossible.
Have I misunderstood the relation between color_temp
and max_mireds
or does Hue (or HA) lie to me about its capacity?
