Hello.
I am trying to get the gas consumption on my house heating by using a broadlink sp3s consumption.
The heater in idle is 2.75w when is recirculating water is 57w and when the gas is starting to heat is above 98w.
Now I am using
Not sure how that configuration works for you. It’s not valid yaml. If you want to take instantaneous energy and convert it to Wh or kWh, then you’d need to use the integration integration. Then use that sensor for utility meter.
Yes but what you posted is not valid, so you either copy/pasted the code blocks from 2 sections of your code or it’s doing nothing and you think its doing something.
