Calculated sensor
Beginner question:
I still have a lot to learn…
I’ve been looking for the solution all day.
I have two sensors A and B.
However, I still want a third sensor .
Sensor C = sensor A - sensor B.
How do I do that?
Do I have to enter the calculation
Sensor: make ?
Or should/can I do the calculation in Utility Meter:
I do want to keep the calculated value C in the database
I have below code.
sensor`:
  - platform: rest
    json_attributes:
        - waterquantity
    resource: http://192.168.0.101/water.html
  - platform: rest
    json_attributes:
        - waterquantity
    resource: http://192.168.0.100/water.html
utility_meter:
  hourly_Meter_A:
    source: Meter_A_quantity
    cycle: hourly
  hourly_Meter_B:
    source: Meter_B_quantity
    cycle: hourly
  *hourly_Meter_C:*
*     source: Meter_C_quantity*
*     cycle: hourly*
Use a template sensor.
template:
  - sensor:
      - name: "Your Sensor Name Here"
        unit_of_measurement: "your_unit_here"
        state: "{{ states('sensor.your_sensor_a_here')|float(0) - states('sensor.your_sensor_b_here')|float(0) }}"
Thank you for your help.
I had tried this solution, but it doesn’t seem to work with the utility meter_C.
If meter_A and meter_B count then Utility meter_C has the same value as utility meter_A
meter_B does not seem to be subtracted from meter_A.
Utility meter_A and B indicate the correct value.
sensor`:
  - platform: rest
    json_attributes:
        - waterquantity
  - platform: rest
    json_attributes:
        - waterquantity
template:
  - sensor:
      state: '{{(states.sensor.meter_A.attributes["waterquantity"] | float | round(0))- (states.sensor.meter_B.attributes["waterquantity"] | float) | round(0)}}'
      state_class: "measurement"
      unit_of_measurement: "l"
      icon: "mdi:water"
 utility_meter:
  hourly_Meter_A:
    cycle: hourly
  hourly_Meter_B:
    cycle: hourly
  hourly_Meter_C:
    cycle: hourly
Entity ids only contain lower case letters. Also use this format to prevent errors if the sensor is not initialised:
template:
  - sensor:
      state: "{{ ( state_attr('sensor.meter_a', 'waterquantity')|float(0) - state_attr('sensor.meter_b', 'waterquantity')|float(0) )|round(0) }}"
      icon: "mdi:water"
https://www.home-assistant.io/docs/configuration/templating/#states
Also your source entity ids are not correct for your utility metres:
 utility_meter:
  hourly_Meter_A:
    source: Meter_A_quantity   # What is this?
You need to provide a valid entity id there.
I still have a lot to read and learn!
Below is my original code.
The quantity sensors from meter A,B and C are correct (1870 - 626 = 1244 ).
For now only the quarter-hourly and hourly sensors are representative.
The others sensors are not running long enough yet.
The (utility) meters from Meter C does not do what I expect (meter_a - meter_b = meter_c).
  - platform: rest
    json_attributes:
    - waterquantity
  - platform: rest
    json_attributes:
    - waterquantity
template:
  - sensor:
      name: "meter_a quantity"
      state: "{{ ( state_attr('sensor.meter_a','waterquantity')|float(0)|round(0)) }}"
      icon: "mdi:water"
  - sensor:
      name: "meter_b quantity"
      state: "{{ ( state_attr('sensor.meter_b', 'waterquantity')|float(0)|round(0)) }}"
      icon: "mdi:water"
  - sensor:
      name: "meter_c quantity"
      icon: "mdi:water"
utility_meter:
  quarter_meter_a:
     source: sensor.meter_a_quantity
     cycle: quarter-hourly
  hourly_meter_a:
    cycle: hourly
  quarter_meter_b:
    source: sensor.meter_b_quantity
  hourly_meter_b:
    cycle: hourly
  quarter_meter_c:
    source: sensor.meter_c_quantity
  hourly_meter_c:
     cycle: hourly
  daily_meter_a:
    cycle: daily
  daily_meter_b:
    cycle: daily
  daily_meter_c:
     cycle: daily
  monthly_meter_a:
    cycle: monthly
  monthly_meter_b:
    cycle: monthly
  monthly_meter_c:
    cycle: monthly
You can’t use the utility meter for C. That gives a running total. All you want is the difference between Utility meters A and B. Use template sensors to do this.
Thank you very much Tom,
I get what you mean and I have it working now :flushed:.
Not easy for a 60+ to start a new hobby.
