Hi there,
I want to calculate and show the difference between two temperature sensors.
Copied and re-worked some script exemples but it doesn’t work. Got this after installing:
Failed config
sensor.template: [source /config/esphome/wplogger.yaml:56]
platform: template
unit_of_measurement: C
[value_template] is an invalid option for [sensor.template]. Please check the indentation.
value_template: |-
{{ states(('Supply water Temperature')|float(0) - states('Retour water Temperature')|float(0))|round(1) }}
This what I worked out
# Individual temperature sensors
- platform: dallas
address: 0x05092330588d5028
name: "Retour water Temperature"
filters:
throttle_average: 300s
- platform: dallas
address: 0x9509233033081b28
name: "Supply water Temperature"
filters:
unit_of_measurement: "C"
value_template: >
You’re using the legacy format for defining template sensors, which is still supported, but is no longer recommended. It looks like you might have mixed some config style from the new format and the old format.
You also need to use the entity id, not the friendly name as the argument to states()
In the legacy format, it would look like this:
But while you’re making changes, you might as well switch to the new style for template sensors which uses template as a top level platform and would look like this:
