Calculation of Current (Ampere) in template sensor?
hi,
my shelly EM does only supports Voltage(V), Power (W) and Powerfactor (%), but unfortunately not Current (A).
so i want to create a template senor for it.
i have read, that for calculation for AC, i have to consider powerfactor as well, and i can´t simply use “current=power/Voltage”
but all formulas i has found the powerfactor is calculated with cosφ (I = P / (U x cosφ))…but the shelly only give me %?
how do i calculate current with the given shelly infos correctly? and how is the template syntax for that?
thanx in advance
br
Frank
I don’t own a Shelly EM, so cannot be 100% sure, but I think that the power factor in this case is:
Power factor = 0% → cosφ = 0
Power factor = 100% → cosφ = 1
So just divide the Power factor value by 100 and you should be good.
