I can’t seem to get Home-assistant’s caldav component with custom_calendars to work with all day events anymore like I used quite a while back with my vacuum automation.
I’ve re-built my Home-assistant install from scratch to get a clean start, still no luck. As you can see below I even reduced the search to a catch all regex rather than searching for Vacuum
Another thing I tried was using the full Nextcloud calendar path i.e. https://example.tld/remote.php/dav/calendars/dugite-code/house-and-home/
However I didn’t think that would do anything as by the looks of it HA is seeing the event in the calendar and is just ignoring it.
Any ideas?
Setup:
- Home Assistant 0.101.2 (Docker)
- Nextcloud 17
Config:
logger:
default: critical
logs:
homeassistant.components.caldav: debug
calendar:
- platform: caldav
url: https://example.tld/remote.php/dav/
username: dugite-code
password: !secret caldav
custom_calendars:
- name: vacuum
calendar: 'House and Home'
search: '.*'
Log:
[homeassistant.components.caldav.calendar] No matching event found in the 1 results for House and Home
