I have just testing caldav on my hassio installation running 0.109.
Caldav server access works when used from eg calendar app on macos.
However, in ha it doesn’t. The debug log shows:
2020-04-30 12:27:27 ERROR (MainThread) [homeassistant.components.calendar] caldav: Error on device update!
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 322, in _async_add_entity
await entity.async_device_update(warning=False)
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 472, in async_device_update
await self.hass.async_add_executor_job(self.update)
File "/usr/src/homeassistant/homeassistant/components/caldav/calendar.py", line 143, in update
self.data.update()
File "/usr/src/homeassistant/homeassistant/util/__init__.py", line 240, in wrapper
result = method(*args, **kwargs)
File "/usr/src/homeassistant/homeassistant/components/caldav/calendar.py", line 206, in update
vevent = event.instance.vevent
AttributeError: 'NoneType' object has no attribute 'vevent'
I have events in the calendar… So I am not sure where to search.
I have put the logger to debug level, not more detail.
Clues welcome!
GV
