since update to 0.95.4 my caldav integration is not working anymore
Following error message:
Error while setting up platform caldav
File "/usr/local/lib/python3.7/site-packages/vobject/base.py", line 529, in __getattr__
return self.contents[toVName(name)][0]
KeyError: 'vevent'
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 126, in _async_setup_platform
SLOW_SETUP_MAX_WAIT)
File "/usr/local/lib/python3.7/asyncio/tasks.py", line 416, in wait_for
return fut.result()
File "/usr/src/homeassistant/homeassistant/components/caldav/calendar.py", line 84, in setup_platform
cust_calendar.get(CONF_SEARCH)))
File "/usr/src/homeassistant/homeassistant/components/caldav/calendar.py", line 106, in __init__
super().__init__(hass, device_data)
File "/usr/src/homeassistant/homeassistant/components/calendar/__init__.py", line 83, in __init__
self.update()
File "/usr/src/homeassistant/homeassistant/components/calendar/__init__.py", line 149, in update
if not self.data or not self.data.update():
File "/usr/src/homeassistant/homeassistant/util/__init__.py", line 224, in wrapper
result = method(*args, **kwargs)
File "/usr/src/homeassistant/homeassistant/components/caldav/calendar.py", line 172, in update
results.sort(key=lambda x: self.to_datetime(
File "/usr/src/homeassistant/homeassistant/components/caldav/calendar.py", line 173, in <lambda>
x.instance.vevent.dtstart.value
File "/usr/local/lib/python3.7/site-packages/vobject/base.py", line 531, in __getattr__
raise AttributeError(name)
AttributeError: vevent
