Calendars have worked for along time, now oddly 2 of the calendars don’t get read for some reason. They are there and other calendars are read. Work, Home, RHS 2022-23 are in the same caldav login. Family and Reminders not read?
Error log output:
Logger: homeassistant.components.calendar
Source: components/caldav/calendar.py:212
Integration: Calendar (documentation, issues)
First occurred: 10:24:58 AM (1 occurrences)
Last logged: 10:24:58 AM
caldav: Error on device update!
File “/usr/src/homeassistant/homeassistant/helpers/entity_platform.py”, line 507, in _async_add_entity
await entity.async_device_update(warning=False)
File “/usr/src/homeassistant/homeassistant/helpers/entity.py”, line 739, in async_device_update
await task
File “/usr/local/lib/python3.10/concurrent/futures/thread.py”, line 58, in run
File “/usr/src/homeassistant/homeassistant/components/caldav/calendar.py”, line 147, in update
self.data.update()
File “/usr/src/homeassistant/homeassistant/util/init.py”, line 190, in wrapper
result = method(*args, **kwargs)
File “/usr/src/homeassistant/homeassistant/components/caldav/calendar.py”, line 212, in update
results = self.calendar.search(
File “/usr/local/lib/python3.10/site-packages/caldav/objects.py”, line 1063, in search
for i in components:
File “/usr/local/lib/python3.10/site-packages/vobject/base.py”, line 639, in
return (i for i in self.getChildren() if isinstance(i, Component))
File “/usr/local/lib/python3.10/site-packages/vobject/base.py”, line 631, in getChildren
for objList in self.contents.values():
RuntimeError: dictionary changed size during iteration
Home Assistant 2023.2.5
Supervisor 2023.01.1
Operating System 9.5
Frontend 20230202.0 - latest
Integration: Calendar ([documentation](https://www.home-assistant.io/integrations/calendar), [issues](https://github.com/home-assistant/home-assistant/issues?q=is%3Aissue+is%3Aopen+label%3A%22integration%3A+calendar%22))
First occurred: 08:55:09 (1 occurrences)
Last logged: 08:55:09
Traceback (most recent call last): File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py",
line 507, in _async_add_entity await entity.async_device_update(warning=False) File "/usr/src/homeassistant/homeassistant/helpers/entity.py",
line 739, in async_device_update await task File "/usr/local/lib/python3.10/concurrent/futures/thread.py",
line 58, in run result = self.fn(*self.args, **self.kwargs) File "/usr/src/homeassistant/homeassistant/components/caldav/calendar.py",
line 147, in update self.data.update() File "/usr/src/homeassistant/homeassistant/util/__init__.py",
line 190, in wrapper result = method(*args, **kwargs) File "/usr/src/homeassistant/homeassistant/components/caldav/calendar.py",
line 212, in update results = self.calendar.search( File "/usr/local/lib/python3.10/site-packages/caldav/objects.py",
line 1063, in search for i in components: File "/usr/local/lib/python3.10/site-packages/vobject/base.py",
line 639, in <genexpr> return (i for i in self.getChildren() if isinstance(i, Component)) File "/usr/local/lib/python3.10/site-packages/vobject/base.py",
line 631, in getChildren for objList in self.contents.values(): RuntimeError: dictionary changed size during iteration
So for me, I was using a secrets file. I put the username and password directly in config.yml and the issue disappeared. I recreated the secrets file and am using secret! now and everything is back to normal.
Didn’t work for me… created a new specific password try that… Nothing.
Disabled a integration that uses also iCloud (iCloud3 tracker) and same issue is there.
Removed CalDav from configuration file to load. Restart HA, put it back and restart HA.
Didn’t work also…
