Hi. I can’t connect HA calendar to Synology Calendar. I use all yours recommendations, but calendar in HA don’t received calendar data.
HA ver: 20230608.0 - latest in docker container Synology.
HA logs:
Logger: homeassistant.components.calendar
Source: helpers/entity_platform.py:254
Integration: Календарь (documentation, issues)
First occurred: 12:55:47 (1 occurrences)
Last logged: 12:55:47
Setup of platform caldav is taking longer than 60 seconds. Startup will proceed without waiting any longer.
Source: components/caldav/calendar.py:87
First occurred: 12:56:16 (1 occurrences)
Last logged: 12:56:16
Error doing job: Future exception was never retrieved
File
“/usr/local/lib/python3.11/concurrent/futures/thread.py”, line 58, in run
File “/usr/src/homeassistant/homeassistant/components/caldav/calendar.py”, line 87, in setup_platform
calendars = client.principal().calendars()
File “/usr/local/lib/python3.11/site-packages/caldav/davclient.py”, line 411, in principal
self._principal = Principal(client=self, *largs, **kwargs)
File “/usr/local/lib/python3.11/site-packages/caldav/objects.py”, line 480, in init
cup = self.get_property(dav.CurrentUserPrincipal())
File “/usr/local/lib/python3.11/site-packages/caldav/objects.py”, line 210, in get_property
foo = self.get_properties([prop], **passthrough)
File “/usr/local/lib/python3.11/site-packages/caldav/objects.py”, line 235, in get_properties
response = self._query_properties(props, depth)
File “/usr/local/lib/python3.11/site-packages/caldav/objects.py”, line 171, in _query_properties
return self._query(root, depth)
File “/usr/local/lib/python3.11/site-packages/caldav/objects.py”, line 196, in _query
ret = getattr(self.client, query_method)(url, body, depth)
File “/usr/local/lib/python3.11/site-packages/caldav/davclient.py”, line 459, in propfind
return self.request(url or self.url, “PROPFIND”, props, {“Depth”: str(depth)})
File “/usr/local/lib/python3.11/site-packages/caldav/davclient.py”, line 629, in request
return self.request(url, method, body, headers)
File “/usr/local/lib/python3.11/site-packages/caldav/davclient.py”, line 654, in request
[Previous line repeated 962 more times]
File “/usr/local/lib/python3.11/site-packages/caldav/davclient.py”, line 582, in request
r = self.session.request(
File “/usr/local/lib/python3.11/site-packages/requests/sessions.py”, line 589, in request
resp = self.send(prep, **send_kwargs)
File “/usr/local/lib/python3.11/site-packages/requests/sessions.py”, line 703, in send
r = adapter.send(request, **kwargs)
File “/usr/local/lib/python3.11/site-packages/requests/adapters.py”, line 486, in send
resp = conn.urlopen(
File “/usr/local/lib/python3.11/site-packages/urllib3/connectionpool.py”, line 714, in urlopen
httplib_response = self._make_request(
File “/usr/local/lib/python3.11/site-packages/urllib3/connectionpool.py”, line 466, in _make_request
six.raise_from(e, None)
File “”, line 3, in raise_from
File “/usr/local/lib/python3.11/site-packages/urllib3/connectionpool.py”, line 461, in _make_request
httplib_response = conn.getresponse()
File “/usr/local/lib/python3.11/http/client.py”, line 1375, in getresponse
response.begin()
File “/usr/local/lib/python3.11/http/client.py”, line 337, in begin
self.headers = self.msg = parse_headers(self.fp)
File “/usr/local/lib/python3.11/http/client.py”, line 236, in parse_headers
return email.parser.Parser(_class=_class).parsestr(hstring)
File “/usr/local/lib/python3.11/email/parser.py”, line 67, in parsestr
return self.parse(StringIO(text), headersonly=headersonly)
File “/usr/local/lib/python3.11/email/parser.py”, line 56, in parse
feedparser.feed(data)
File “/usr/local/lib/python3.11/email/feedparser.py”, line 176, in feed
self._call_parse()
File “/usr/local/lib/python3.11/email/feedparser.py”, line 180, in _call_parse
self._parse()
File “/usr/local/lib/python3.11/email/feedparser.py”, line 295, in _parsegen
if self._cur.get_content_maintype() == ‘message’:
File “/usr/local/lib/python3.11/email/message.py”, line 621, in get_content_maintype
ctype = self.get_content_type()
File “/usr/local/lib/python3.11/email/message.py”, line 605, in get_content_type
value = self.get(‘content-type’, missing)
File “/usr/local/lib/python3.11/email/message.py”, line 498, in get
return self.policy.header_fetch_parse(k, v)
File “/usr/local/lib/python3.11/email/_policybase.py”, line 316, in header_fetch_parse
return self._sanitize_header(name, value)
File “/usr/local/lib/python3.11/email/_policybase.py”, line 287, in _sanitize_header
if _has_surrogates(value):
RecursionError: maximum recursion depth exceeded
