While it’s great that the calendar.list_events can retrieve future events based on them occuring in a future period of time, it would be good to also return the next {X} events regardless of when they are in the future.
alias: N-Quantity Events from calendar
description: A script to return a given number of calendar events.
fields:
quantity:
description: The number of events to return.
example: 5
required: true
selector:
number:
min: 1
max: 100
calendar:
description: The calendar entity to retrieve event information from.
example: calendar.example
required: true
selector:
entity:
domain: calendar
sequence:
- service: calendar.get_events
end_date_time: "{{now() + timedelta(days=365)}}"
entity_id: "{{ calendar }}"
response_variable: agenda
- variables:
scheduled: "{{ {'events': agenda[calendar].events[:quantity]} }}"
- stop: Return the response variable back to the calling script or automation
response_variable: scheduled
mode: single
EDIT: Updated to use calendar.get_events
I was just looking for this feature. Where does this need to be created?
What I posted above is a script. Once created it can be called as a service from automations, scripts, or trigger-based template sensors.
- service: script.n_quantity_calendar_events
calendar: calendar.example
quantity: 5
response_variable: x
- service: notify.notify
message: |
Your next 5 calendar events are as follows {{ x.events | map(attribute='summary') | join(', ') }}
Hhmmmm
What im wanting is to show the list of upcoming events on the Dashboard. Right now i just have the standard calendar card.
Basically show the date, time and subject of the next ‘x’ events.
You may want to check out Atomic Calendar Revive Card. It’s a flexible and feature-packed card with both Calendar and list (“Event”) viewing modes. You can use the maxEventCount
configuration option to limit the number of events shown when using Event Mode.
