Hello everyone,
I’m new to this forum and hope I’m posting in the right section, seeking advice or guidance. If this is not the correct place, please accept my sincerest apologies and direct me to the appropriate section.
Here’s my issue:
I have successfully installed an instance of Home Assistant (HAS) on my Raspberry Pi and configured it with Google Calendar. So far, everything has been running smoothly. When I add an event to my Google Calendar, it syncs with HAS, displaying all events just as I entered them. Additionally, I’ve integrated Telegram and generated a bot, which is configured in the config.yaml file as a notifier. I set up an automation that triggers 15 minutes before an event is scheduled to start. This automation sends a notification through the bot to my phone via Telegram. The configuration is as follows:
alias: Calendar Trigger
description: ""
- platform: calendar
event: start
offset: "-0:15:0"
entity_id: <MY_CALENDAR>
condition: []
- service: notify.<MY_NOTIFICATION_NAME>
message: >
Here’s an event coming up.
Event: {{state_attr('calendar.<MY_CALENDAR>', 'message') }}
Notes: {{state_attr('<MY_CALENDAR>', 'description')}}
type: tts
mode: single
However, I’m encountering a problem. Everything functions correctly until the automation triggers for the first time. The automation sends a Telegram message with the first event’s notes and title. But, if the automation triggers again, the bot repeats the message from the first event in the calendar. This issue is particularly pronounced if I have a full-day events in my calendar - it gets stuck looping over the full-day event instead of sending messages for each event as they appear in the calendar, sorted by time. Any assistance or guidance would be highly appreciated.
