Calendar updating when events change
I am going to try to use the google calendar sensor to trigger prinkler on/off. Pretty easy automation. But what I notice a new calendar entry with search criteria doesn’t get picked up by HA immediately , is there a interval between calendar updates? A stop and restart of hass picks it up.
Looks like 15 minutes from the code:
# Return cached results if last scan was less then this time ago
MIN_TIME_BETWEEN_UPDATES = timedelta(minutes=15)
Good to know, thanks
What code is this? Can I change the duration?
Response a bit late, but Reload Core will actually force updating the calendar
