Hi guys, I recently bought a Calex Smart Wall Switch only to figure out this isn’t officially supported in ZHA.
However, it is in Z2MQTT: Calex 421782 control via MQTT | Zigbee2MQTT
Also see: Calex Dimmer Switch Colour Control (421782) Zigbee compatibility
ZHA does recognize the device so I thought I’d use the event listener to fetch the events myself and create a blueprint.
The on, off, and dim buttons are working fine and I even figured out the W button (switch color temperature to a random value).
The only issue I have is with the RGB. The switch fires a enhanced_move_to_hue_and_saturation event on cluster id 768 (whatever that means…) but there are no arguments passed that I can send to a sequence to set the color values or anything.
It almost seems like this device is just telling to “rotate through RGB values” or something, not sure…
It actually sends two events when trying to set a color:
First:
"event_type": "zha_event",
"data": {
"device_ieee": "00:15:8d:00:02:4f:3b:bb",
"unique_id": "00:15:8d:00:02:4f:3b:bb:1:0x0300",
"device_id": "cd4f7431b1eaeccd8ce5858ad65dfe45",
"endpoint_id": 1,
"cluster_id": 768,
"command": "color_loop_set",
"args": [
15,
0,
0,
0,
0
"origin": "LOCAL",
"time_fired": "2022-02-02T23:49:55.384259+00:00",
"context": {
"id": "341b419d520890bdf72020b8dd1e5e2f",
"parent_id": null,
"user_id": null
Second:
"data": {
"endpoint_id": 1,
"cluster_id": 768,
"command": "enhanced_move_to_hue_and_saturation",
"args": []
"origin": "LOCAL",
"time_fired": "2022-02-02T23:49:55.521128+00:00",
"context": {
"id": "5a8fc04bddd5214fb8455b2762fe4f8f",
"parent_id": null,
"user_id": null
If anyone has more info on how to proceed with this, please let me know!
blueprint:
name: ZHA - CALEX - Smart remote - Custom Actions
description: >-
This automation simulates the use of the Calex Dimmer Switch Colour Control
domain: automation
input:
remote:
name: Calex remote control
description: Select the remote control you wish to use.
selector:
device:
integration: zha
# manufacturer: Calex
# model: Smart Wall Switch
light:
selector:
entity:
domain: light
# dim_step:
# name: Dim step
# description: The dim amound in percentage
# default: 10
# selector:
# number:
# min: 0
# max: 100
# unit_of_measurement: percentage
mode: restart
max_exceeded: silent
- platform: event
event_type: zha_event
event_data:
device_id: !input remote
- variables:
command: "{{ trigger.event.data.command }}"
cluster_id: "{{ trigger.event.data.cluster_id }}"
endpoint_id: "{{ trigger.event.data.endpoint_id }}"
args: "{{ trigger.event.data.args }}"
- choose:
# Short-Press on the ON button.
- conditions:
- "{{ command == 'on' }}"
sequence:
- service: light.turn_on
target: !input light
# Short-Press on the OFF button.
- conditions:
- "{{ command == 'off' }}"
sequence:
- service: light.turn_off
# Short-Press on the DIM UP button.
- conditions:
- "{{ command == 'step' }}"
- "{{ args == [0, 42, 3] }}"
sequence:
brightness_step_pct: 10
# transition: 1
# Short-Press on the DIM DOWN button.
- conditions:
- "{{ args == [1, 42, 3] }}"
sequence:
brightness_step_pct: -10
# transition: 1
# Hold on the DIM UP button.
- conditions:
- "{{ command == 'move' }}"
- "{{ args == [0, 100] }}"
sequence:
- repeat:
count: 10
sequence:
# transition: 1
- delay: 0.5
# Hold on the DIM DOWN button.
- conditions:
- "{{ args == [1, 100] }}"
sequence:
- repeat:
count: 10
sequence:
# transition: 1
- delay: 0.5
# Short-Press on the W button.
- conditions:
- "{{ command == 'move_to_color_temp' }}"
sequence:
color_temp: "{{ args.0 }}"
transition: "{{ args.1 }}"
default: []
