Hi guys.
I have 2 netatmo thermostat at home and I use netatmo action in order to change rooms temperature considering water temperature of my air pump. Automation works well and I’m able to modulate my air pump and avoid on / off.
I’ve problems with current temperature valves.
Valves temperature are very different from real ones (they are higher). Also if I calibrate them from netatmo app they will not work properly in a while.
I have Aquara sensor in every room. Is there a way to calibrate valves temperature using Aquara temperature using home assistant automation?
I try to find a netatmo action that calibrate valves temperature but I do not find nothing.
Can anyone help me?
Riccardo
